73SwingerBuild
Up for sale is my Holley model 3310-3 4160 style carb. It's a vacuum secondary carb rated at 750CFM and the choke assembly was removed by the previous owner.
The carb was completely disassembled and rebuilt 8 months ago, but I didn't check the jet or power valve specs because it was on the motor when I got it so I didn't want to change anything.
I ran it on my 340 up until a week ago and the motor LOVED the carb at the top end, but it was just too much for the street, so I downsized. This carb worked great with no issues. Never had the engine backfire through it, and even without a choke it started and idled fine.
There was a small repair made to the base (looks like somebody tightened it down when it wasn't sitting flat, so the corner must have chipped off. You can see where they welded it back on). The weld is good and it doesn't leak at all. I know this for a fact.
I'll also include the dual inlet fuel feed line, which also never leaked.
Asking $200 shipped from North Smithfield, RI (02896).
Thanks for looking.
-Mike
Thanks for looking.
-Mike
