FS - Jeep SRT8 Exhaust Manifolds - $200 shipped
Uhcoog1
Houston
I know this isn't the For Sale section, but I wanted the hemi guys to see it.
I have a set of Jeep SRT 8 exhaust manifolds I am no longer going to use. These fit great with the AlterKtion. I have the factory K member, and they hit the steering box and the torsion bar is kinda in the way.
The SRT8 manifolds have primary tubes wrapped with a heat shield- you can see in my pictures that I notched into the heat shield on the drivers side manifold to see if I could make them fit my factory steering (didn't make it work). Anyway, there is a small opening in the heat shield that doesnt affect the primaries, but I would weld it shut if I were you (I'm not a good welder- I started to try and decided it was a bad idea).
$170+$30 shipping = $200 shipped for lower 48.
Are you running a Manual box that these are hitting? I have a duster, motors not quite in yet so I don't know what kind of room I have. Was thinking of running these, been told they would work with 5.7 w/ stock k member.
Thanks
Jason
They will not work with a manual box without completely re-routing #1 cylinder primary. If they're new, you could maybe make it work. But if they're used, the flange will bend if you cut it.
