MidnightSwinger
318 Aspen Wagon:
I live in Vegas and daily drive my Wagon. 318 factory 4bbl with eddy 600 on top. I of course have all the fun problems with that combo and 100°+ temps and stop and go driving. Vapor lock, fuel percolation, the fun stuff.
My question is this: What it the best setup for the feed line? The line that goes from the pump to the filter/carburator.
I bought the car with a metal line that runs in front of the engine, and attaches to the filter and fuel pump using fuel hose. I don't believe that this is the factory feed line, and I believe it may be causing some of my issues.
Should I look for the correct feed line from a stock LA or could I build something better? Any ideas and input about fuel lines and insulating them is very much appreciated.
I am running the stock mechanical fuel pump, and would like to stay away from an electric fuel pump if possible.
Thanks
I attached a crappy picture of the current feed line. It almost looks stock, but it doesn't thread into the fuel pump, it uses rubber fuel hose.
Thanks
