Fuel Filter Empty
Fuel and Air Systems
  1. Paladin06
    Paladin06 Well-Known Member
    1,073
    280
    Jan 19, 2010
    East Valley, AZ USA
    Local Time:
    2:44 PM
    On to my next item to fix on my 1972 Plymouth Duster 340. I've noted that after the car sets for awhile, the fuel filter is completely empty. There are no obvious fuel leaks visible.
    Where should I start.
    Thanks in advance.
    Greg
  2. Yote
    Yote Well-Known Member
    1,166
    476
    Aug 30, 2015
    far eastern Colorado
    Local Time:
    3:44 PM
    Wish I could help . My '72 340 is the same way. Takes quite a bit of cranking to start.
    Yote
    • Like Like x 1
    • Yote
      1,166
      476
      Aug 30, 2015
      Local Time:
      3:44 PM
      Yote
    • mopar head
      mopar head Well-Known Member
      2,648
      361
      Oct 21, 2008
      Right here, can`t you see me?
      Local Time:
      4:44 PM
      New fuel pump.
      • Like Like x 1
      • mderoy340
        mderoy340 Well-Known Member
        2,054
        771
        Aug 2, 2012
        Melbourne FL
        Local Time:
        5:44 PM
        Check valve in the fuel pump leaking.
        • Like Like x 2
        • Paladin06
          1,073
          280
          Jan 19, 2010
          East Valley, AZ USA
          Local Time:
          2:44 PM
          Thanks guys. Recommendations on a good one.
        • sireland67
          sireland67 Well-Known Member
          7,945
          1993
          Oct 27, 2010
          WV
          Local Time:
          5:44 PM
          Carter sells a muscle car series, for around $30.
          • Like Like x 1
          • pishta
            pishta I know I'm right....
            14,245
            3914
            Oct 13, 2004
            Tustin, CA
            Local Time:
            2:44 PM
            Does your pump have round body with screws or is it crimped? There are 2-3 rubber flap (outlet valves) pressed in there. One may not be seating. I have found the little rubber pucks dislodged and sitting at the base of the pump.
            • Like Like x 1
            • Abodybomber
              Abodybomber Breaking street machines , since 1983.....:) Legendary Member
              31,731
              10451
              May 21, 2011
              Arroyo grande ca
              Local Time:
              2:44 PM
              M6270 ,IIRC....
              • Like Like x 1
              • Mattax
                Mattax Just the facts, ma'am FABO Gold Member
                5,889
                3259
                Feb 7, 2013
                Phila. Pa
                Local Time:
                5:44 PM
                M6270 was the 'competition' pump and had a cut off pressure of 7.5 psi. In other words, needs a regulator.
                M6902 was the 'Super Street' pump and had a cut off pressure of 6 psi. That's was the better choice for 99% of users.
                Can't speak to the recent reissue of these pumps personally, but have read here of pressure regulation issues.
                If replacing, I'd suggest a stock replacement, or Holley 110 mechanical if there is uncertainty about the cut-off (aka maximum pressure).
                • Like Like x 1
                • Yote
                  1,166
                  476
                  Aug 30, 2015
                  Local Time:
                  3:44 PM
                  My fuel pump was new less than 3 years ago and problems stated above have been with me since and car was not operable before that.
                  Yote
                  • Like Like x 1
                  • dibbons
                    dibbons Well-Known Member
                    2,847
                    1203
                    Nov 6, 2009
                    La Paz, B.C.S., Mexico
                    Local Time:
                    2:44 PM
                    Is it vapor? When i ran a Holley double pumper it was set up with two transparent fuel filters immediately before the carb inlets. The filters normally looked only half full--until I added an aluminum "cool can" and added ice at the drag strip--the filters thereafter would be completely full (as long as the ice held out, that is). I was using a Holley electric fuel pump with pressure regulator at the time (no mechanical pump).
                    • Like Like x 1
                    • Paladin06
                      1,073
                      280
                      Jan 19, 2010
                      East Valley, AZ USA
                      Local Time:
                      2:44 PM
                      OK, I replaced the fuel pump and BINGO.. Another thing noted is the fact that before the pump change with the car running the filter was never completely full. Now it is completely full. Also the car has set over night and the filter is still full this morning.
                      Thanks @mopar head and all the rest!
                      • Like Like x 1
                      • Thanks! Thanks! x 1
                      • Paladin06
                        1,073
                        280
                        Jan 19, 2010
                        East Valley, AZ USA
                        Local Time:
                        2:44 PM
                        Ok spoke to soon. Took the car to the about 6 miles round. Car started to run funny. Got home popped the hood and the fuel filter was damn near empty. No fuel leaks but an oil leak around the pump. WTF. Man I can not get a break. Guess I’ll need a new pump, again.
                      • 69FBCuda
                        69FBCuda Life in the Fast Lane
                        1,411
                        604
                        Aug 28, 2014
                        Florida
                        Local Time:
                        5:44 PM
                        If the fuel pump loses pressure after shutoff and the Float seat in the carb loses the vacuum while setting, the gas flows down hill
                        • Agree Agree x 2
                        • mopar head
                          2,648
                          361
                          Oct 21, 2008
                          Local Time:
                          4:44 PM
                          While your at it, maybe verify their is no fuel restriction or vent problems.
                          Hopefully it`s just a bum pump and you can replace and drive happily ever after
                          • Like Like x 1
                          • Paladin06
                            1,073
                            280
                            Jan 19, 2010
                            East Valley, AZ USA
                            Local Time:
                            2:44 PM
                            The new pump was working just fine when I drove the car around the block after I replaced it. The filter was staying full of fuel over night. Today oil leak at the pump and zero fuel in the filter.
                          • RichB
                            RichB CherryCuda65
                            279
                            133
                            Feb 10, 2016
                            South Carolina
                            Local Time:
                            5:44 PM
                            I have the same hard starting problem with my 65 Barracuda. Are you implying that the stock type fuel pump can be repaired or Rebuilt? I'm tired of trying different fuel pumps and would like to see the problem and then know that it's fixed.
                          • mopar head
                            2,648
                            361
                            Oct 21, 2008
                            Local Time:
                            4:44 PM
                            Oil leak is on you. Make sure your oil does not smell like gas. Re seal, run/drive shut down, remove gas cap and notice if it makes a woosh vacume sound.
                            If you have over a 1/4 tank of gas, jack up the back of the car a little and remove the inlet line to the pump into a tub, with gas cap off, gas should flow. If not, may be time to pull the sender and inspect.
                            As post 15 states, could be the culprit too. What carb. are you running?
                            • Like Like x 2
                            • pishta
                              14,245
                              3914
                              Oct 13, 2004
                              Tustin, CA
                              Local Time:
                              2:44 PM
                              If it's the non crimped round one with the Allen bolts holding the upper and lower together, yes, it is repairable. Crimp is a throw away. What carb is this? Carter won't lose fuel unless it's boiling it out, very common without a phenolic/wood/plastic spacer. Neither will a holley but those bowls are more insulated from the intake heat. Both (all) carbs use engine vacuum to pull fuel out the bowls. None have a built in drain 'cept the TQ with bad jet O-rings. I finally went to a carter electric in my 65 cartered 340 as the bowls would be dry every morning. 5 seconds of pumping and the bowls would be full and the car would start under 1 revolution. I'm sure it was heat soak caused as I never had driveability issues.
                            • mopar head
                              2,648
                              361
                              Oct 21, 2008
                              Local Time:
                              4:44 PM
                              Yea, this guy is in AZ hell heat. Don`t know how hot it is there yet. Seems a carb heat spacer would be a must out west.
                              • Agree Agree x 1
                              • RichB
                                RichB CherryCuda65
                                279
                                133
                                Feb 10, 2016
                                South Carolina
                                Local Time:
                                5:44 PM
                                I have a Carter AFB on an aluminum manifold. Should I try an insulating carb spacer?
                              • pishta
                                14,245
                                3914
                                Oct 13, 2004
                                Tustin, CA
                                Local Time:
                                2:44 PM
                                Absolutely! Carter on an AL intake is like a pot of water on a grill. You can make one out of MDF or marine plywood or just buy a plastic one. Even nylon washers under the mounting bolts will block heat transfer.
                                • Like Like x 1
                                • Paladin06
                                  1,073
                                  280
                                  Jan 19, 2010
                                  East Valley, AZ USA
                                  Local Time:
                                  2:44 PM
                                  I happen to have one I can sell you. It’s brand new never installed.
                                • Paladin06
                                  1,073
                                  280
                                  Jan 19, 2010
                                  East Valley, AZ USA
                                  Local Time:
                                  2:44 PM
                                  Yes it’s going to hit 108 today. Not to bad. Waiting for those 115 days
