Tommiez
Member
So I installed the Dolphin fuel gauge ohm converter today.. It was pretty straight forward.. It had me connect power, ground and a wire going to the gauge and one the sending unit. You take the cover off the converter and move the sending unit to full and press a f button, than move it to half and hit the h button and then empty.. After putting it together and I put 5 gallons in it and it read between empty and 1/4.. then i put another few gallons in it and it was a little more than a 1/4.. I just filled it up and went a little past full.. I will see how this tank works.. before when I went about 100 miles it was empty and only took 4-6 gallons to fill it back up..
