Fuel injection for the slant six
Slant 6 Engines
  1. hemichuck
    hemichuck Well-Known Member
    929
    90
    Jan 12, 2012
    Louisville Kentucky
    Local Time:
    7:52 AM
    ive got a 63 Dart Wagon that’s a slant six and it’s in real good shape so I was considering maybe putting an aftermarket fuel injection setup on it. Anybody done this? What did you use? And what were the results?
  2. 65 Dartman
    65 Dartman FABO Gold Member FABO Gold Member
    10,737
    2550
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    7:52 AM
    There's a couple of guys over at slant6.org using FitEch FI on an Offy 4 barrel intake. Several others are using MPFI controlled by aftermarket controllers.
    • Like Like x 1
    • Disagree Disagree x 1
    • low_kota
      low_kota Well-Known Member
      236
      27
      Aug 3, 2010
      Overland, MO
      Local Time:
      6:52 AM
      It will be a while before I get it all installed, but I ordered a Holley sniper 2300 and a tanks inc. EFI tank and fuel pump.
      • Like Like x 1
      • toolmanmike
        toolmanmike FABO Staff Staff Member FABO Gold Member
        45,784
        29890
        Jan 18, 2006
        Iowa
        Local Time:
        6:52 AM
        I think port injection would be best for a straight 6.
        • Agree Agree x 3
        • 64DartGTinAZ
          64DartGTinAZ FABO Gold Member FABO Gold Member
          2,523
          652
          Aug 14, 2010
          Phoenix
          Local Time:
          5:52 AM
          I'm still a ways off from getting it installed (the guy at Fox Engineering ran onto some hard times and never sent me the controller that I paid him for as part of the package - stopped even responding with sob stories after 2 years of me ask, "Hey, how's it coming along?" - it's on his 'customer photos' page, and he took it to some shows before he shipped it to me...thanks for 2/3 of what I paid for, Fran...and 3 years wait to get that part)
          • Like Like x 4
          • 65 Dartman
            10,737
            2550
            Sep 24, 2006
            Strasburg, VA
            Local Time:
            7:52 AM
            Looks like a triple Weber intake - individual throttle bodies?
          • J Glenn
            J Glenn FABO Gold Member FABO Gold Member
            150
            47
            Sep 6, 2017
            Minneapolis
            Local Time:
            6:52 AM
            Does anyone make a kit, or are people generally adapting v6 injection to their slant6's?
          • flingdingo
            flingdingo Well-Known Member
            244
            200
            Apr 26, 2017
            El Lay
            Local Time:
            4:52 AM
            Holley makes a Carter BBD-style Sniper that's marketed to the Jeep guys. That might work if you're looking for the drivability of FI. But like Toolmanmike said, port injection is really the way to go on any inline 6. It eliminates all the fuel delivery problems inherent in the looong wet manifold.
          • flingdingo
            244
            200
            Apr 26, 2017
            El Lay
            Local Time:
            4:52 AM
            I'm looking at adapting BMW's 3.5 liter FI stuff, controlled with Megasquirt. It's an inline engine, and really close in displacement to the 225. I may be a bit biased though, as I worked on them for almost 20 years, and am very familiar with the system.
            • Thanks! Thanks! x 1
            • 383Scampman
              383Scampman Well-Known Member
              1,518
              747
              Nov 24, 2013
              New Hampshire
              Local Time:
              7:52 AM
              I would look into using a later model Jeep 4.0L setup with the H.O. intake .
            • jos51700
              jos51700 Well-Known Member
              5,145
              1832
              May 24, 2009
              Bel-Ray
              Local Time:
              6:52 AM
              Wasn't Pishta making these? I thought I remember him doing a pretty good job of this.
            • wish4hemi
              wish4hemi Well-Known Member
              814
              102
              Aug 26, 2009
              62450
              Local Time:
              6:52 AM
              Not worth it to adapt a system. It used to be back when turn-key aftermarket solutions weren't available. I did the research (and others have) to adapt a 454 TBI system on to a 440. And GM 3800 port injection to a 225 slant. It made sense 15 years ago, but now you can get an aftermarket setup with full technical support for so cheap these days that it is not in any way feasible to try and adapt an old system.
              The Holley 2300 EFI system is $850 for the base kit and FiTech has a similar offering for $795. If you have a stocker slant 6, one of those is your best bet.
            • flingdingo
              244
              200
              Apr 26, 2017
              El Lay
              Local Time:
              4:52 AM
              Both of those systems are still a TBI into a wet manifold. Port injection will be much more efficient, and potentially make more power.
              As I said earlier, fine if you're just looking to enhance driveability, but not the best choice for an inline engine. Especially if you are willing to/have the ability to play around.
            • my68barracuda
              my68barracuda Well-Known Member
              1,030
              692
              Dec 6, 2009
              Indianapolis IN
              Local Time:
              7:52 AM
              Have to agree with that, why spend money on fuel injection system that has a wet manifold.
              I run a MS3 Pro on a slant.
              Using Ford blue top injectors in a Clifford intake that has the nitros bosses drilled to accept the injectors. A gm 3.8/5.0 throttle body matches up with the other gm engine sensors. The MS3 also runs the ignition, using a locked lean burn distributor to fire a MSD box. I ran into an issue with underhood electronic interference, which is not uncommon with aftermarket FI, got that resolved and all is good.
              I plan to set it up to run E85 next year to take advantage of the higher octane and run higher compression.
              • Like Like x 1
              • RustyRatRod
                RustyRatRod Weenie idiot loser. FABO Gold Member
                58,022
                28121
                Jun 7, 2010
                Georgia
                Local Time:
                7:52 AM
              • RustyRatRod
                58,022
                28121
                Jun 7, 2010
                Georgia
                Local Time:
                7:52 AM
                Do you have some pictures please?
              • flingdingo
                244
                200
                Apr 26, 2017
                El Lay
                Local Time:
                4:52 AM
                I'd like to see your setup also
              • my68barracuda
                1,030
                692
                Dec 6, 2009
                Indianapolis IN
                Local Time:
                7:52 AM
                this photo shows the fuel rail, Clifford intake, ported throttle body, this was taken prior to setting up the MDS ignition, when a HEI was in use.
                I cannot get more recent photos as the car is stripped for upgrades over the winter.
                • Like Like x 6
                • 67Dart273
                  67Dart273 FABO Gold Member FABO Gold Member
                  41,311
                  8977
                  Oct 14, 2010
                  Idaho
                  Local Time:
                  4:52 AM
                  Most of us would never know the difference between a wet or dry manifold..............'specially on a mild slant..........
                  The big big nonsense about the terribleness of TBI was the era in which they were OEM........and the poor state of development of the surrounding electronics
                  Plus there's been some fairly impressive engine builds with various Holley/ FI / other TBI systems
                  But THE OTHER THING is, you an easily scrape together a TBI, and if you use something like a MS or Holley HP computer, you can convert it later to multiport and still use the same TBI if you want, for a TB on the multiport
                • my68barracuda
                  1,030
                  692
                  Dec 6, 2009
                  Indianapolis IN
                  Local Time:
                  7:52 AM
                  "never know the difference between a wet or dry manifold..............'specially on a mild slant.."
                  Dat tru,, so for a mild slant build, if it was me, I would just stay with a carburetor. Save the money that would be spent on
                  a TBI system and spend that on a nice set of wheels, a lot more people will notice.
                  • Agree Agree x 1
                  • 67Dart273
                    41,311
                    8977
                    Oct 14, 2010
                    Idaho
                    Local Time:
                    4:52 AM
                    Now you are just being silly, OK? You might want to include the rest of my argument.............
                    "Plus there's been some fairly impressive engine builds with various Holley/ FI / other TBI systems"
                    Furthermore there are some pretty impressive systems running "wet."
                  • 64DartGTinAZ
                    2,523
                    652
                    Aug 14, 2010
                    Phoenix
                    Local Time:
                    5:52 AM
                    Yes on the triple Weber intake - throttle bodies are pairs a la 'Dual Webers'
                  • cdnEHbody
                    cdnEHbody Well-Known Member
                    429
                    128
                    Oct 24, 2015
                    regina sask canada
                    Local Time:
                    6:52 AM
                    Go to slant six.org guy on there running it has a good write up on. Get sick of listening to all the experts talk you out of tbi cause "its no good" or "wont work"
                    Has a fitech. Says it.runs excellent. Easy starts when hot or cold. Better mileage. Probably a bit more power id guess.
                  • BillGrissom
                    BillGrissom Well-Known Member
                    7,301
                    359
                    May 10, 2009
                    Sacramento
                    Local Time:
                    4:52 AM
                    Pishta here made MPFI by drilling ports into a slant head. Unless the Chinese make an intake, you probably won't see an MPFI intake for <$400. Throttle-body injection is much easier, but doesn't fix the mal-distribution that plagues straight-six intakes, though the 4 bbl intakes do have a bigger chamber under the carb that should help. For my 1964 slant, I have several aluminum intakes and injectors w/ rails from a Mopar V-6 that "should work" if staggered. Will look a bit Frankenstein'ed, if I ever get to it. At the intake, you only need to seal for vacuum leaks. Some rodder's have posted a brass plumbing fitting you can use that the injector ends fit snuggly into, then usually epoxy to the intake outside. I wouldn't secure with an internal nut since bad if that falls off and gets sucked into the engine, though you might stake it as they do on throttle plate screws. For fuel control, I have Holley Commander 950 and older Pro-jection 2D. Check back after I'm retired and have time to fool with such. I haven't even been home in 2 weeks.
                  • Mike Cummins
                    Mike Cummins Member
                    12
                    3
                    Dec 31, 2019
                    Metro/Detroit
                    Local Time:
                    7:52 AM
                    Thanks for your input. Because My car is a simple stock vehicle, this solution sounds reasonable for the money.
