fuel line routing
shiifty_dart
Illinois
how do you guys have your feul lines routed Ive seen some that come up through the inner fenders with the line in the wheel well but does that cause any problems and how do you connect the line to the carb
thanks Joren
You need a bulkhead fitting. and some stainless steel braid line to go the carb. I ran aluminum line under the fender with rubber hose over it for protection from stones. I ran it this way to avoid as much heat as i can to keep the gas cooler.
