1. Scamp Rhonda
    Scamp Rhonda Well-Known Member
    783
    740
    Jan 18, 2017
    Blaine MN
    Local Time:
    5:39 AM
    Ok, Next question RRR, how do you make the original gas cap vented?
    I'm following this because my charcoal canister is gone and the line is just hanging out in the engine compartment. Lol. Mine is a72 Scamp. Thanks Steve
    • Like Like x 1
    • RustyRatRod
      RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
      79,494
      57956
      Jun 7, 2010
      Georgia
      Local Time:
      6:39 AM
      I simply get a 1/16 drill bit and go right through the under side of the cap. Not the outside, but the under side in such a way as to miss the sealing area, otherwise it will not vent. Just flip it over and look at it. It's pretty obvious where to drill. Done a lot of them like that through the years.
      • Like Like x 1
      • Thanks! Thanks! x 1
      • Scamp Rhonda
        783
        740
        Jan 18, 2017
        Blaine MN
        Local Time:
        5:39 AM
        Then I can plug the vent tube at the gas tank and get rid of the line going back to where the canister used to be?
      • RustyRatRod
        79,494
        57956
        Jun 7, 2010
        Georgia
        Local Time:
        6:39 AM
        Sure, but keep in mind, the way I am describing to vent the cap is a 24/7 vent, it's not like a vented cap with a valve that builds pressure and vacuum and then vents. It will be vented all the time. I don't know why you would want to do away with that vent line though. I would rather use it for a liquid fuel return.
        • Scamp Rhonda
          783
          740
          Jan 18, 2017
          Blaine MN
          Local Time:
          5:39 AM
          Ok, I'm gonna have to reread the post. I think you showed us a three nipple fuel filter. That is what I should connect the return line to correct? Thanks and sorry dartfreak for overtaking the post.
        • RustyRatRod
          79,494
          57956
          Jun 7, 2010
          Georgia
          Local Time:
          6:39 AM
          Yes, that's correct.
          • Like Like x 1
          • Scamp Rhonda
            783
            740
            Jan 18, 2017
            Blaine MN
            Local Time:
            5:39 AM
            Awesome, thanks RRR and good night. Lol
            • Agree Agree x 1
            • dartfreak75
              dartfreak75 Restore it, Dont part it! FABO Gold Member
              10,829
              8448
              Aug 10, 2011
              Virginia
              Local Time:
              6:39 AM
              go back to 38 and watch that video that is what rusty is talking about this is how I'm gonna do mine all you would have to do is run a 1/4 fuel hose from the line that goes to the canister to the third nipple on the fuel filter. That like goes back to the top of the tank
              • dartfreak75
                10,829
                8448
                Aug 10, 2011
                Virginia
                Local Time:
                6:39 AM
                You good dude. I like when people get Involved in these type of threads and learn with me lol. Hope this thread helds you as much as it has me.
                • Like Like x 1
                • dartfreak75
                  10,829
                  8448
                  Aug 10, 2011
                  Virginia
                  Local Time:
                  6:39 AM
                  Got the tank out this morning. Another one of those 1 step forward 2 back situations. Remember the rust in the trunk I found? Well I really found it!! The entire hanger ripped out when I tried to loose the j-bolt! :BangHead: Good news is I got the tank and sending unit out. I'm gonna clean up the sending unit. Is the little screen filter in the end removable and replaceable? I didn't mess with it a whole lot I didnt want to break it too. Haha
                • 72Dinger
                  72Dinger Well-Known Member
                  105
                  74
                  Aug 6, 2019
                  Craphole, VA
                  Local Time:
                  6:39 AM
                  I guess what has me confused in all this is if you use the old charcoal can line as a vapor return to the tank, don't you still technically need a vent to atmosphere somewhere? Or does the cap function as the vent? I'm reading lots of conflicting information about whether the 72+ caps are true vents.
                  Vented gas cap?
                  EDIT: Maybe not "conflicting" information, but I'm having trouble understanding it anyway.
                  • Agree Agree x 1
                  • dartfreak75
                    10,829
                    8448
                    Aug 10, 2011
                    Virginia
                    Local Time:
                    6:39 AM
                    Yes you still have to vent the tank. The idea that I had was to run a line out of the top of the tank but rusty's Idea is alot easier you just drill and vent the cap. Or buy one that is vented already it does the the same thing as my idea just much easier. When gas gets hot it expands have you ever seen a full gas jug at the end of the day when you been mowing all day? It's all swole up thats the same thing your tank will do without some sort of vent. The return line simply relifes that same pressure that's made at the fuel pump and in the fuel lines and gives it a place to go. Back to the tank.
                  • 72Dinger
                    105
                    74
                    Aug 6, 2019
                    Craphole, VA
                    Local Time:
                    6:39 AM
                    What i've read so far seems to indicate that the 72+ gas caps relieve excess pressure, but are not necessarily designed to allow air to enter the tank as the fuel level depletes.
                  • dartfreak75
                    10,829
                    8448
                    Aug 10, 2011
                    Virginia
                    Local Time:
                    6:39 AM
                    Idk but I know for a fact my 75 didnt vent it good enough. When I would fill up completely it would hiss and build pressure and eventually blow it back out of the filler tube.
