Fuel pressure help
Discussion in 'Fuel and Air Systems' started by Fisher, Aug 1, 2018.
  1. Fisher
    Fisher Old Guy with a Cool car.
    1,716
    611
    Jul 22, 2012
    Regina Sask Canada
    Local Time:
    5:52 AM
    I have a new Holley Blue pump and regulator which i installed today. Issue is 2 gauges installed , the one at the carb reads 1.5 lbs less than the one on the cowl? The cowl is 7.5 and the carb 6. Which is correct? Both are tapped at the same place.
  2. Dana67Dart
    Dana67Dart Most undignified way to get to Colorado!
    1,503
    578
    Jul 16, 2017
    Northern Colorado
    Local Time:
    4:52 AM
    Neither! being a bit sarcastic but unless the gauges are calibrated they will only be close. eliminate the engine compartment one if you need to keep a watch while driving. will 1.5 psi make or brake your fuel system?
  3. brian6pac
    brian6pac Well-Known Member
    3,018
    1513
    Nov 15, 2016
    N.E.Ohio
    Local Time:
    6:52 AM
    Your autogauge is not at 0 it's way low so I would say that gauge is junk.
  4. pishta
    pishta I know I'm right....
    13,546
    3307
    Oct 13, 2004
    Tustin, CA
    View My Photos
    Local Time:
    3:52 AM
    There is a vent on top of the guage. The hotter it gets, the lower it reads unvented. you can unscrew the brass screw on top (?) to vent then return it but there were posts that said drill a .020 in the screw itself to permanently vent the guage. See if this fits your guages description. I know the rubber boot is the vent on top. venting should return you to zero.
    found this on Moparts. Note red test gauge and yellow unfilled against unvented liquid filled gauges over heat.
    • Like Like x 1
    • Agree Agree x 1
    • Fisher
      1,716
      611
      Jul 22, 2012
      Regina Sask Canada
      Local Time:
      5:52 AM
      Thank you for the replies. I am going to remove the Engine compartment one and leave the cowl one in play.
    • Dana67Dart
      1,503
      578
      Jul 16, 2017
      Northern Colorado
      Local Time:
      4:52 AM
      good catch. How often we all miss the obvious.
    • pishta
      13,546
      3307
      Oct 13, 2004
      Tustin, CA
      View My Photos
      Local Time:
      3:52 AM
      its not junk, just needs its ears popped.
      • Like Like x 1
      • Agree Agree x 1
      • brian6pac
        3,018
        1513
        Nov 15, 2016
        N.E.Ohio
        Local Time:
        6:52 AM
        Good call, never thought of that
      • Fisher
        1,716
        611
        Jul 22, 2012
        Regina Sask Canada
        Local Time:
        5:52 AM
        I took it off the car and plugged the hole, then popped the little rubber plug off it and the gauge sort of zeroed itself. I will leave it off.
        • Like Like x 1
