fuel pump draining back to tank
Fuel and Air Systems
  1. KJoeZ61
    KJoeZ61 FABO Gold Member FABO Gold Member
    290
    54
    Apr 4, 2017
    Northampton Pennsylvania
    Local Time:
    11:07 AM
    I bought a cool carb kit last weekend at Carlisle for my Quick Fuel. So I went to install it today and noticed when I disconnected the fuel line at the filter it was dry. It's been hard starting when sitting for several days or longer. I replaced the fuel pump for the same reason last year. It's a Delphi from AutoZone. Anyone have a better place to buy a stock fuel pump?
    The cool carb kit. Only had it on and drove for about 45 minutes and restarted without a sputter. So far I think it's a big improvement over the Edelbrock insulator gasket I had on. Idled much better at stops, so far I'm impressed. Blaming both of the issues on the ethanol. Even before I put the Edelbrock insulator on and just had a gasket, you could see the fuel boiling in the carb.
    • Agree Agree x 2
    • billccm
      billccm Well-Known Member
      86
      52
      May 13, 2018
      Tucson
      Local Time:
      8:07 AM
      Did you buy the thick, or standard?
      Interested if this works for you.
      • Like Like x 1
      • 70aarcuda
        70aarcuda Master Hoader of SBM FABO Gold Member
        14,134
        2192
        Jan 16, 2005
        las vegas
        Local Time:
        8:07 AM
        not the ethanol...gasoline is blended for fuel injection...not carbs...so i evaporates fast...
      • KJoeZ61
        290
        54
        Apr 4, 2017
        Local Time:
        11:07 AM
        Bought the thin one because I have a height issue. This includes the base plate and spacer and 3 gaskets. All in all it only goes up about 1/2", but I see a noticeable difference. Don't know about the blend, but this summer in Pennsylvania the gas sucks for old school cars, and I still blame the enathol!
        My question was "better fuel pump recomandations?"
        • Like Like x 1
        • Thanks! Thanks! x 1
        • AJ/FormS
          AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
          15,429
          4485
          Jan 19, 2014
          South-Central Manitoba,Canada, 900ftelevation
          Local Time:
          10:07 AM
          water don't run uphill, and neither does gas.
          There is only one way for the gas to actually return to the tank, and that is if the tank is not venting, and develops a vacuum.
          More likely is that the pump is sucking air.
          Or that after the engine is shut off, the fuel is boiling in the line, when the float drops..... due to it boiling in the bowl. Then possibly the vapor pressure in the hot tank, forces fuel up the line and it boils in the pump, and the fumes escape thru the now continuously open float-valve.... Next morning the tank has cooled off, the vapor contracted,and it pulled the fuel back.
          IDK I like the story.
          Check your venting.
          • Like Like x 2
          • Agree Agree x 1
          • toolmanmike
            toolmanmike FABO Staff Staff Member FABO Gold Member
            37,162
            19390
            Jan 18, 2006
            Iowa
            Local Time:
            10:07 AM
            A big problem with AFB/AVS/Edelbrock carbs. I bought a insulator as well. I have been eyeing them at the Nats for a few years. Like the owner said, Edelbrocks have a very small float bowl that sits right over the intake. It's very easy to boil/vaporize the fuel during a hot soak.
            • Agree Agree x 2
            • Like Like x 1
            • BigBlockMopar
              BigBlockMopar BigBlockMember
              1,579
              539
              May 1, 2011
              Netherlands
              Local Time:
              5:07 PM
              A simple electric fuel pump takes care of empty bowls in about a second.
              Having cooler gasoline is a good thing, and an insulating spacer always helps with that.
              • Like Like x 1
              • Agree Agree x 1
              • mderoy340
                mderoy340 Well-Known Member
                2,013
                727
                Aug 2, 2012
                Melbourne FL
                Local Time:
                11:07 AM
                Your check valves are leaking. This is what I use with a dead head regulator and 3/8 fuel line from the tank for steady 1/4 mile WOT flow. Summit regulator is set to 6.5 psi OOTB.
                Carter Strip Super Mechanical Fuel Pumps M6270
              • 69hemibeep
                69hemibeep Well-Known Member
                233
                62
                Jul 18, 2010
                AZ
                Local Time:
                8:07 AM
                Here is my non scientific observation and poll. I have been working on quite a few mopars at my place over the last few years and noticed the cars with Carter or Edelbrock carb's after running stink up the garage for a couple days due to evaporation and are hard to start due to dry carb's after a few days. The cars with Holley carb's don't smell and restart easy weeks later. So at a car show with a number of Mopar owners there I did a survey and found the same results.
                • Agree Agree x 2
                • KJoeZ61
                  290
                  54
                  Apr 4, 2017
                  Local Time:
                  11:07 AM
                  That's actually what I was thinking. I have a Quick Fuel HR-650 on it and it's great, but I was told no more than 6psi of fuel pressure. So if I go with the Carter I would need a regulator, right?
                • mderoy340
                  2,013
                  727
                  Aug 2, 2012
                  Melbourne FL
                  Local Time:
                  11:07 AM
                  Yes. Run the regulator as is, it is set at 6.5 from the factory. I run a demon and QF with this regulator and both of my cars run great.
                • TrailBeast
                  TrailBeast Slightly Twisted Member
                  19,499
                  5927
                  Mar 11, 2011
                  Arizona
                  Local Time:
                  8:07 AM
                  One thing to keep in mind is that a lot of people talk about the fuel getting or running back to the tank.
                  The only fuel that runs back is what is in the lines, as it is not physically possible for the fuel in the carb bowls to run back.
                  Evaporation is what empties bowls.
                  On another note, I know a lot of people don't like the thought of running an electric pump.
                  The electric IS the way to have instant fuel in the carb and instant starts.
                  After the electric my car starts pretty much before you can get your hand off the key.
                  Here's a video to prove it.:D
                  This is first thing in the morning and the car had not been started since early the day before.
                  (Neighbors mower was running in the background)
                  www.letsgocomputers.com/dart/morningfire.avi
                  • Agree Agree x 1
                  • 70aarcuda
                    14,134
                    2192
                    Jan 16, 2005
                    las vegas
                    Local Time:
                    8:07 AM
                    the eddy/carter carb accelerator pump well does not extent itself down to the bottom of the fuel bowl so once the gas evaporate below the well....you have no shot to start the car....the holley accelerator pump is on the bottom of the bowl and there for will provide a shot of gas longer....
                    my e85 carbs on the race car sit for month and still squirt gas to start the engine....that is 85% ethanol...
                    • Agree Agree x 2
                    • KJoeZ61
                      290
                      54
                      Apr 4, 2017
                      Local Time:
                      11:07 AM
                      it was dry even in the filter.
                    • KJoeZ61
                      290
                      54
                      Apr 4, 2017
                      Local Time:
                      11:07 AM
                      Has anyone used the Edelbrock 1720? Its supposed to be set for 6psi.
                    • oldkimmer
                      oldkimmer FABO Gold Member FABO Gold Member
                      10,443
                      1290
                      Nov 11, 2006
                      Kindersley, Saskatchewan,
                      Local Time:
                      10:07 AM
                      The filter is not always full, it can have almost no fuel to being full when running, it just the way the system works. Kim
