Fuel system for 6.4
New Hemi Engine Swaps
  1. CurtDawg510
    CurtDawg510 Well-Known Member
    103
    31
    Nov 18, 2013
    Hayward, ca
    Local Time:
    5:13 AM
    so im at the point where im gunna need to build up my fuel system...
    Its a 6.4 hemi with a cam in a 70 duster
    i like the idea of a return system... i was thinking for now, run a regulator up close to the engine, with a small amount on fuel line in dead head only to fuel rails (for now)... i want to change fuel rails later, so fuel can circulate threw them with regulator... (after its running and on road)
    My question is what is a good fuel pump setup? I was looking at this
    Aeromotive Gen II Stealth Fuel Tanks 18444
    What yall think??
    Thanx
  2. Heywodja
    Heywodja The Heartbeat Stops Here. FABO Gold Member
    401
    80
    Aug 16, 2014
    Texas
    Local Time:
    7:13 AM
    Hat
    • Disagree Disagree x 1
    • Heywodja
      401
      80
      Aug 16, 2014
      Texas
      Local Time:
      7:13 AM
      wrong Thread
      • retroron
        retroron FABO Gold Member FABO Gold Member
        617
        404
        Apr 9, 2014
        Livermore Calif
        Local Time:
        5:13 AM
        That's the fuel pump system I'm running on my 6.4, with the regulator mounted on the fire wall in the return line.
      • CurtDawg510
        103
        31
        Nov 18, 2013
        Hayward, ca
        Local Time:
        5:13 AM
        Perfect, you got the first hand experience with this one!.... how you like it? Pumps enough fuel/psi... pump loud, or quiet like new cars??
      • retroron
        617
        404
        Apr 9, 2014
        Livermore Calif
        Local Time:
        5:13 AM
        I've lead you along I fear. I have the pump, etc. in my Dart. But, I haven't started the car yet, I'm a couple of weeks away. But I do have the same pump and regulator on my race car (picture attached) and it is very quiet and fuel pressure is easy to set.
        • Like Like x 1
        • Chuckbizkits
          Chuckbizkits Well-Known Member
          403
          300
          Sep 18, 2007
          North Orange County, CA
          Local Time:
          7:13 AM
          I'm running a brand X LS regulator/filter. It has a built in return. I mounted it close to the tank with a short return line. $30 or so at Autozone. Tanks has a great line of pumps and tanks for the swap.
          • Agree Agree x 1
          • Peter Bates
            Peter Bates 1973 Cuda owner for 36yrs
            137
            108
            Aug 25, 2018
            Sylvania ohio
            Local Time:
            8:13 AM
            I used the GM style filter that has a return port to tank. Tank is a Holley sniper. Works great and the filter is inexpensive. Put it above my axle.
          • retroron
            617
            404
            Apr 9, 2014
            Livermore Calif
            Local Time:
            5:13 AM
            I used the aeromotive stealth system and mounted the regulator on the firewall to make it easy to set the fuel pressure, you can see it in the picture
