What is every one using for a fuel system? on cars that go 11.00 and quicker.
What fuel pump?
What regulator?
What line size?
This should help all racers as well.
:burnout:
Yes I understand what you are saying,
What I meant was that it takes a certain amount of horsepower to take 3600 pounds into the 11s, whereas it takes a different amount of power to take 2800 pounds into the 11s. or2200 pounds into the 11s,etc.
Since the OP didn't specify how much weight he needed to propel, we cannot know how much horsepower we are dealing with, and therefor how much fuel to supply, and therefor what minimum pump might be sufficient.
Am I out in left field here?
See, I knew I was in trouble right from the get-go.Thank you Rodzilla
