Fuel tank replacement - What seals to order?
Fuel and Air Systems
  1. AircoolerKirk
    AircoolerKirk Active Member
    32
    43
    Feb 25, 2019
    Allen, Texas
    Local Time:
    4:27 PM
  2. fratzog lover
    fratzog lover Well-Known Member
    12,220
    9237
    Jun 7, 2013
    Maple Shade New Jersey
    Local Time:
    5:27 PM
    Keep the old sender lock ring! Many repops are bad copies resulting in leaks. Someone posted a while back where to get a quality seal, they are not all created equal.
    • Like Like x 1
    • KosmicKuda
      KosmicKuda FABO Gold Member FABO Gold Member
      1,537
      378
      Jan 15, 2011
      N Ohio
      Local Time:
      5:27 PM
      I replaced the tank in my 64 Valiant with one I got from Vans Auto ax they had a good price..
      My tank pad was torn but in reasonable shape so I used it as a pattern to make one out if PSA closed foam sheet.
      I ohmed out my original sending unit and it seemed fine so reused it. Some of the after market pieces do not give accurate levels. Reused the original locking ring.
      I ordered a filler pipe grommet but can't remember if I used it or not.
      My strap was good so I bead blasted and powder coated it.
