Fuel tank sending unit
Discussion in 'Electrical and Ignition' started by buck351, Oct 26, 2018.
  1. buck351
    buck351 Well-Known Member
    421
    57
    Apr 22, 2010
    Campton Hills, IL
    View My Photos
    Local Time:
    8:14 AM
    Lately I replaced the sending unit since gauge was not registering very accurately. Current replacement not any better so I ordered on from Classic Industries that is suppose to be made to match OEM specs. Question about the filter on the pickup tube. I was having trouble getting the old one out and when I got it out the filter on the pickup tube had come off in tank. I don't see anyway of getting it out without removing the tank. So will it float or sink to the bottom. If it sinks to the bottom my not cause problems. Wondering if it will interfere with the sending unit float.
  2. Dana67Dart
    Dana67Dart Most undignified way to get to Colorado!
    1,502
    578
    Jul 16, 2017
    Northern Colorado
    Local Time:
    7:14 AM
    Don't know if it would float or sink, BUT the filler is a very straight shot and with a flashlight you can see into the tank. You might get lucky with a long grabber and be able to find it. USE EXTREME CAUTION WITH ELECTRONICS AND FUEL TANK!!!!!
    Also with the tank empty and the sender out you might be able to find it.
    My best guess is if you do nothing it will just be in there and cause no harm. If the sender stops functioning then pull tank as it may have gotten stuck somewhere.
    By the way how is the Classic sender working out?
  3. buck351
    421
    57
    Apr 22, 2010
    Campton Hills, IL
    View My Photos
    Local Time:
    8:14 AM
    Hard to see in the sending unit hole with other items of the car in the way. Haven't received the Classic Industries one yet. I will post back on how it works related to amount of fuel the tank takes compared to the gauge reading. The current one in the tank reading 1/4 tank takes 8 gallons to fill it.
  4. Freezerman
    Freezerman Well-Known Member
    252
    50
    Jul 4, 2013
    Prior Lake, MN
    Local Time:
    8:14 AM
    You need to get a metermatch from technoversions. Its a little box you connect between the sending unit and the gauge. It has an adjustable correction factor in it for the resistance in the sending unit. It works very well.
    • Like Like x 1
    • Agree Agree x 1
    • Dana67Dart
      1,502
      578
      Jul 16, 2017
      Northern Colorado
      Local Time:
      7:14 AM
      Agreed. Thought. disconnect shocks, and let rear droop to the max might buy some "head" room. WATCH brake lines!
    • buck351
      421
      57
      Apr 22, 2010
      Campton Hills, IL
      View My Photos
      Local Time:
      8:14 AM
      The sending unit came today from Classic Industries. Did a quick check on ohms from each stop on the float travel. Range is 7.2 to 68.5. The old one that came out on the last replacement is 77 to 10. According to a post here the OEM should be 10 to 63.5 . Don't know what the range is on the one that's was put in about 3 weeks ago.
    • Dana67Dart
      1,502
      578
      Jul 16, 2017
      Northern Colorado
      Local Time:
      7:14 AM
      Can you post a photo of the unit?
      Part of the issue IMHO is that some of the aftermarket sending units do not have the same travel as the OE unit and as such will stay at full for longer and show empty longer. Also the liner vs non liner aspect of things.
    • toolmanmike
      toolmanmike FABO Staff Staff Member FABO Gold Member
      33,920
      15819
      Jan 18, 2006
      Iowa
      View My Photos
      Local Time:
      8:14 AM
      None of the repops are accurate as the originals.
      • Agree Agree x 1
      • Dana67Dart
        1,502
        578
        Jul 16, 2017
        Northern Colorado
        Local Time:
        7:14 AM
        This is what I got from a Mopar OEM (OE replacement from Dodge) sending unit and the aftermarket that was in the tank at the time. The OEM unit is very accurate.
