Funny short circuit
dibbons
La Paz, B.C.S., Mexico
All lights work fine on my '65 Signet convertible. However, with the engine off, key removed from the ignition, if I step on my brake pedal, the dash lights come on, let off the brake pedal, the dash lights go off! Weird.
If entire park lamp circuit is coming on ( tag lamp, etc.. ), One possible cause is lack of chassis ground at rear lamp fixtures.
You either have poor grounds at the rear lamps (most likely), or a single contact bulb (1156) in a dual contact socket (1157)..
One of your tailamps isn't working properly..
Clamp the bare end of a length of wire to your trunk striker,, take the other bare end and touch it to your taillite bulb bases, re-check problem..
