Fury won't start
Electrical and Ignition
  1. benz junkie
    benz junkie Member
    8
    0
    Mar 27, 2017
    North Carolina
    Local Time:
    12:57 PM
    I have a 1976 Fury Salon that will crank and start very briefly but will cut off almost immediately. The engine will not run on starter fluid or if you hold the throttle down. It just starts and then shuts off. I was wondering about the ignition once it goes from the start position to the run position.
  2. SGBARRACUDA
    SGBARRACUDA ROY FABO Gold Member
    13,572
    3258
    Dec 7, 2006
    PLANT CITY FL.
    Local Time:
    12:57 PM
    Sounds like you may have a bad ballast resistor.
  3. benz junkie
    benz junkie Member
    8
    0
    Mar 27, 2017
    North Carolina
    Local Time:
    12:57 PM
    It has been replaced with a 4 connector resistor, is there a way to test it.
  4. krazykuda
    krazykuda FABO Gold Member FABO Gold Member
    46,856
    11856
    Aug 20, 2007
    Orland Park, IL
    Local Time:
    11:57 AM
    I would try another ballast resistor or a new ignition control box....
  5. SGBARRACUDA
    13,572
    3258
    Dec 7, 2006
    PLANT CITY FL.
    Local Time:
    12:57 PM
  6. SGBARRACUDA
    13,572
    3258
    Dec 7, 2006
    PLANT CITY FL.
    Local Time:
    12:57 PM
  7. benz junkie
    benz junkie Member
    8
    0
    Mar 27, 2017
    North Carolina
    Local Time:
    12:57 PM
    I have 1.2 on the bottom terminals and 5 on the top terminals. Can I hook it up to the bottom 2 terminals and use it like a single resistor?
    I have a new control unit that I have installed (it is a 4 pin ) and this has not changed the no start condition.
  8. W-Edge
    W-Edge raceheads.ca
    107
    32
    Mar 8, 2017
    pointe des cascades , quebec
    Local Time:
    12:57 PM
    Not sure bout the 4 connector ones but on the two prong you just bypass it (connect the wires together) if it starts and keeps running after you release the ign sw from start to run , you ve honed in on your problem , just don t run it like that for any extended perion of time , you ll fry the ign.coil and/or ign. box...
  9. benz junkie
    benz junkie Member
    8
    0
    Mar 27, 2017
    North Carolina
    Local Time:
    12:57 PM
    It starts very briefly and cuts off, it seems to stay running if I keep the key turned to the start position.
  10. SGBARRACUDA
    13,572
    3258
    Dec 7, 2006
    PLANT CITY FL.
    Local Time:
    12:57 PM
    • Agree Agree x 1
    • benz junkie
      benz junkie Member
      8
      0
      Mar 27, 2017
      North Carolina
      Local Time:
      12:57 PM
      Using the above mentioned document, I have 12 volts at the ballast resistor and I have 6 volts on my coil (+ side) with key in run position. I am going to try a new ballast resistor.
    • oldkimmer
      oldkimmer FABO Gold Member FABO Gold Member
      10,432
      1289
      Nov 11, 2006
      Kindersley, Saskatchewan,
      Local Time:
      11:57 AM
      ............With ur dual ballast resistor u need a 5 pin box.........kim.........4 pin boxes use a single ballast........
