Fuse box upgrade
Electrical and Ignition
  1. Cam1399
    Cam1399 Well-Known Member
    45
    2
    Aug 30, 2020
    Tennessee
    Local Time:
    5:12 AM
    Has anyone updated their fuse box? Mine are corroded and I’ve added a fuse for electric fans. I saw a fuse relay panel from leash electronics. Would this be a good option to swap the fuse box or what do y’all suggest? Thanks
  2. 67Dart273
    67Dart273 FABO Gold Member FABO Gold Member
    55,325
    25551
    Oct 14, 2010
    Idaho
    Local Time:
    3:12 AM
    I don't keep track anymore, but there are several outfits that sell various fuse boxes. Likely most any of the wire harness outfits. You can (could) even buy them made by buss (fuses)
  3. BKCowGod
    BKCowGod Well-Known Member
    123
    126
    Jan 16, 2022
    Santa Cruz, CA
    Local Time:
    3:12 AM
    I haven't updated the original box, but I have bought a few of these over the years to augment. For $14, they're damn solid and even have the little "blown fuse" LED indicator and a nice ground distribution block! My Dart has one for keyed and one for continuous and they work great.
    https://www.amazon.com/gp/product/B08XWQHMZJ/?tag=fabo03-20
    • Thanks! Thanks! x 1
    • Cam1399
      45
      2
      Aug 30, 2020
      Tennessee
      Local Time:
      5:12 AM
      Would running the keyed on through a relay help things? The leash box has the ignition side run through a relay first. That’s a good price using two. I need to see what is battery hot and keyed
    • BKCowGod
      123
      126
      Jan 16, 2022
      Santa Cruz, CA
      Local Time:
      3:12 AM
      Relays are always a good thing. Supposedly it can handle the amperage, but Chinese amps are calculated differently.
      And to be clear, I use this for aftermarket. Fans, stereo, upgraded lighting, air conditioner, backup cam, etc.
    • Cam1399
      45
      2
      Aug 30, 2020
      Tennessee
      Local Time:
      5:12 AM
      I see some things are battery hot and some are keyed. Do you know what needs to be hot all time and what needs to be keyed? Thanks
    • BKCowGod
      123
      126
      Jan 16, 2022
      Santa Cruz, CA
      Local Time:
      3:12 AM
      Not on your year. On mine, I have radio constant, cigarette lighter, headlights, keyless entry/trunk release, and the a/c fan on constant. Some of those may seem a bit wonky but work for me.
      Really nothing on an older car NEEDS to be constant for the car to work - it was only with the advent of radio memory and computerized engine management that we started adding stuff. Everything else is a luxury - interior lights and other things people want to have when the door opens.
      I recommend buying one of these if you are going to delve too much into your wiring (note, the link is for my car, but the company is great)
      1965 65 Dodge Dart Full Color Laminated Wiring Diagram 11" X 17" | eBay
    • 65 Dartman
      65 Dartman FABO Gold Member FABO Gold Member
      12,876
      4546
      Sep 24, 2006
      Strasburg, VA
      Local Time:
      6:12 AM
      On my 65 Dart I used this Eaton 15305-1 fuse panel of which the sides are separate electrically and use mini blade fuses. I ended up installing it in the glove box.
      I use one side for always Hot and the other side for key On/Acc. I have completely rewired my underdash harness as I am using several Dakota Digital modules which require either always hot or key on OR for one module, both.
      I needed a fuse panel with enough fuses to cover all my requirements for always hot - the Dakota Digital modules, the power tailgate window, power driver’s side seat, driver’s side power lumbar, brake light circuit, parking lights, and auxiliary 12 volt power aka cigar light receptacle. For key On/Acc - heater blower motor, door power windows, heated seats, etc.
      • Like Like x 1
      • Cam1399
        45
        2
        Aug 30, 2020
        Tennessee
        Local Time:
        5:12 AM
        Looks good. This is the one I was looking at. He makes really good products
      • RustyRatRod
        RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
        88,261
        71372
        Jun 7, 2010
        Georgia
        Local Time:
        6:12 AM
        That looks perfect for Vixen. Her fuse box is a little rough. I'll never need more than six fused circuits. Thanks for posting that.
        • Like Like x 1
        • Cam1399
          45
          2
          Aug 30, 2020
          Tennessee
          Local Time:
          5:12 AM
          He makes a lot of drag car controllers too. I like he runs the ignition side through a relay
