I thought I would pass this information on to those that need a pressure bleed system. Years ago I had bought a Motive pressure bleeder for the old bail , cast master cylinders. The part number is 0105. I worked well on the old cast dual master cylinders. But this time I needed it for my latest build, my 68 Barracuda with the late model aluminum master cylinder with the plastic tank. I went on Ebay and bought the adapter kit I needed, which is part number 1113 to use with my old system. Today I bleed the entire new brake system with this set up today. And it worked out Great! I highly recommend this set up, especially if your a one man show like I am. Only used about 3/4 of a quart of brake fluid.
