Blind Squirrel
So I had a pad poured and I thought it came out fairly well. I assembled a metal structure on it and I have some gaps where the pad has low spots. In one spot its just short of a 1/2 inch and maybe 3 ft long. The metal is galvanized sheet steel. What is the best option for a permanent and solid solution to fill any gaps. I need to tighten the anchors but can't pull down at this point without distortion. If I use something to flexible it wont support the anchor and something to ridged that thin or thinner will probably just crack out. The area is also subjected to water. Any great ideas? Thanks in advance.
