1. Captainkirk
    Captainkirk Old School Mopar Warrior
    3,446
    1582
    Apr 24, 2006
    Northern IL
    Local Time:
    3:24 PM
    Here in the bowels of the Midwest (Chicago area) winter can be a Really Big Deal. So much so that it puts the binders on any serious work from mid-November through May, give or take depending on unseasonably warm or cold weather. My 2-1/2 car garage is un-insulated, unheated, and wired for 15 amps/110V, and fuses at that. Looking to find a reasonable solution for heating while I'm out working during the winter months. Given the wiring issues, I'm thinking electric heat may be out of the question for the immediate future. There is no provision for natural gas, either...which leaves me with very few options. And I don't want to get fumed out by a kerosene heater either. Anyone had good luck with a propane-fired heater or electric infared heaters that don't draw a lot of wattage?
  2. el5dart
    el5dart Well-Known Member
    591
    409
    May 16, 2018
    memphis, tn.
    Local Time:
    3:24 PM
    • Like Like x 1
    • Thanks! Thanks! x 1
    • 67Dart273
      67Dart273 FABO Gold Member FABO Gold Member
      49,495
      17749
      Oct 14, 2010
      Idaho
      Local Time:
      1:24 PM
      Electric........there is no magic. "So many watts" (amps) = so much heat. There is no such thing as a magic more efficient electric heater. Heat is about 3400 BTU per kilowatt, PERIOD. A typical bathroom / portable heater is about 1000-1500 watts if that gives you some idea. A leaky uninsulated garage? Almost zero effect. A 1500W heater is going to draw about 13A at 120V so you've "used up" one 15A circuit right there
      Consider LPG Maybe score a used heater/ furnace VENTED if possible. Portable / infra red / salamander stuff can be an explosion/ fire hazard when coupled with solvents, etc.
      NAT gas, do you have it in house? How far is the garage? I have no workable shop, but I have a big shed I heat when I HAVE to, with an old nat gas furnace. I "cheat." I installed a nat. gas "barbecue" quick connect and valve outside the house, and then scored a big length of barbecue gas hose. I just hook it up when I need it
      Oil.....Might look for an old but servicable oil furnace. "If you are handy" you can do some research and install it in one corner
      Wood...already mentioned.
      I have NO idea the codes you are fighting, I bet it is "plenty." If you are doing ANY painting/ solvent/ other flammable, ANY unvented combustion heater and some electric heaters will be an ignition hazard.
      • Like Like x 2
      • Agree Agree x 1
      • Demonracer
        Demonracer 71 Demon 00 Ram 16 Chrysler 300S 05 Caravan FABO Gold Member
        5,083
        3079
        Jan 31, 2010
        Cleveland, Texas
        Local Time:
        3:24 PM
        If it were my shop, I would check into insulation for the walls & put insulation in the crawl space above the shop itself. Since it's not insulated, you be putting more money trying to heat the outside world. I'm in a different climate area but when I extended the storage shed next to my carport from 10' x 8' to 20' x 8', I bought 4 bundles of insulation & put it between the studs before putting up the interior walls. I put a small heat/ac unit in the wall & it keeps my storage area cool in the summer, warm in the winter & I don't have to worry about stuff stored there rusting.
        • Agree Agree x 2
        • Like Like x 1
        • Captainkirk
          3,446
          1582
          Apr 24, 2006
          Northern IL
          Local Time:
          3:24 PM
          Being within city limits, I'm sure there are a ton. I'll bet there's even one against wood burning stoves in an outbuilding. Hell, we can't even burn leaves. LPG might be the way to go, albeit expensive. Any natural gas would require the gas company to trench and install it...not cheap, I'm sure.
        • Captainkirk
          3,446
          1582
          Apr 24, 2006
          Northern IL
          Local Time:
          3:24 PM
          Planning on insulating and paneling, but one step at a time. I built a workbench in one corner and put up R19 and pegboard behind it but that only covers about 12 feet of wall space.
        • 68gtxman
          68gtxman I used to reMember
          4,480
          2991
          Jul 11, 2011
          Eastampton, NJ
          Local Time:
          4:24 PM
          I survived 1 and a 1/4 winters in very cold Korea with two kerosene heaters to heat my 1 bedroom apartment. No supplemental heat either except a Coleman white gas camp stove while fixing dinner. It was enough to make us feel comfortable, but we had to shut it off at night to avoid asphyxiation.
          • Like Like x 2
          • Captainkirk
            3,446
            1582
            Apr 24, 2006
            Northern IL
            Local Time:
            3:24 PM
            Above all it needs to be safe.
            • Agree Agree x 2
            • diymirage
              diymirage HP@idle > hondaHP@redline
              24,702
              21767
              Oct 12, 2012
              michigan
              Local Time:
              4:24 PM
              whatever you do, dont ask @pishta for help
            • abdywgn
              abdywgn dismantler
              1,809
              1059
              Jul 30, 2006
              Darien, Illinois
              Local Time:
              3:24 PM
              how tall is the ceiling? Menard's and others have gas furnace to hang from ceiling...mine is uninsulated so I guess I'm adding to global warming.
              • Like Like x 2
              • Captainkirk
                3,446
                1582
                Apr 24, 2006
                Northern IL
                Local Time:
                3:24 PM
                It "could" be tall enough to hang one in the corner. IF...I was able to get natural gas run out to the garage. That would have to be a summertime thing, I'm guessing, if within a reasonable price range.
              • pishta
                pishta I know I'm right....
                20,328
                9619
                Oct 13, 2004
                Tustin, CA
                Local Time:
                1:24 PM
              • Captainkirk
                3,446
                1582
                Apr 24, 2006
                Northern IL
                Local Time:
                3:24 PM
                • Agree Agree x 2
                • 70duste
                  70duste Well-Known Member
                  165
                  107
                  Aug 25, 2014
                  il
                  Local Time:
                  3:24 PM
                  LP gas hanging furnace ,insulate walls and ceiling, 80k btu is what I have in my 24x30 garage and works fine, that's what I would look into, just put a 100lb tank outside and plumb pipe into heater.
                  • Like Like x 1
                  • gzig5
                    gzig5 FABO Gold Member FABO Gold Member
                    1,705
                    1869
                    May 3, 2018
                    Mequon, WI
                    Local Time:
                    3:24 PM
                    I've got the same issues. My garage is has no insulation to the attic, and I'm not sure about the outside wall. Right now I have a 5kw electric heater in the upper front corner. It knocks the edge off but takes forever to warm up. When it is 20 out I can get to about 45 maybe 50. I'm going to add a LP torpedo heater to get up to temp in about 15 minute and then the electric will hold temp long enough. Eventually I want to put it natural gas up by the ceiling or maybe one of those radiant bar heaters on the ceiling if I can find one I can afford.
                    I need to insulate the attic, but I have so many car parts up there it would take me a week to clear it out so that may wait til the car is back together
                    • Like Like x 1
                    • mopar head
                      mopar head Well-Known Member
                      3,079
                      892
                      Oct 21, 2008
                      Right here, can`t you see me?
                      Local Time:
                      4:24 PM
                      Insulate and upgrade the electric.
                      My buddy hooked me up with a mobile home elec. heater, works great.
                      • Like Like x 1
                      • Agree Agree x 1
                      • pikewi
                        pikewi Comfortably numb
                        227
                        78
                        Oct 18, 2010
                        WI
                        Local Time:
                        3:24 PM
                        Get a used LP furnace from a mobile home. All you need is a 100 lb.. propane tank outside the garage and a line into the garage
                        • Like Like x 1
                        • 69DodgeMan
                          69DodgeMan Well-Known Member
                          153
                          227
                          Aug 4, 2019
                          Indiana
                          Local Time:
                          4:24 PM
                          Don't forget the exhaust VENT back out of the garage.
                        • 67Dart273
                          49,495
                          17749
                          Oct 14, 2010
                          Idaho
                          Local Time:
                          1:24 PM
                          About used..............and if you do the install yourself........
                          Again, be aware of combustion hazards. Been a few years, but ignition sources in a garage are supposed to be 18"? 24" off the floor? This is supposed to be "above" low lying gas vapors, etc, so keep that in mind.
                          It would be better if you find one that is known as "sealed combustion" or "outside air for combustion. Older furnaces draft the intake/ combustion air into the burner right from the heated space.
                          Ideal would be a "downflow" and you could hang that thing up into the "rafters" to get it out of the way and direct the heat downwards
                          Best to-and required most places I'm aware--to keep the LP tank out doors. Be aware that small tanks may not vaporize properly in extreme cold weather. They need enough space in the top to form vapor and keep up with use. So if you are "going cheap" with portable tanks, you may need to run two in parallel to combat the problem
                          Research and be aware of "clearance to combustibles." Many furnaces, overall, only require 1" clearance. "B" vent needs 1" and "C" or single wall pipe is 6". This can be reduced in certain instances with shielding, IE stand off metal sheet with airspace both sides The previous was for gas/ LP and not oil or wood. You can run "B" vent clear outside with a what is called "listed cap." Easy way to avoid roof damage is to elbow it out the gable end, or depending on garage construction, out through high on the side wall and then up past the roof with support brackets. You must have a certain amount of roof clearance depending on roof pitch.
                          So basically you need an LP furnace that's appropriate/ fixable/ useable, some vent, some piping for LP gas and some hose/ connections, and a cord/ cap to plug it in. It does not need to be "hard wired." And of course a cheap wall stat
                          • Agree Agree x 1
                          • LO23M8B
                            LO23M8B Well-Known Member
                            1,095
                            507
                            Jan 30, 2019
                            Michigan
                            Local Time:
                            1:24 PM
                            The kerosene torpedo heaters work good when new or if you know how to repair them. I used them for many years without a ceiling in my garage. They also make a propane torpedo heater. I used 2 kerosene heaters in my garage 28x28 12 foot ceiling a 150,000 and a 50,000. I'd keep the small on on and cycle the large on as needed. Worked great.
                          • A Body 440 WHY NOT
                            A Body 440 WHY NOT Well-Known Member
                            361
                            143
                            Sep 28, 2019
                            Jersey
                            Local Time:
                            1:24 PM
                            I would say a nice wood burning , cast iron stove. toasty
                            • Like Like x 1
                            • Agree Agree x 1
                            • 4spdragtop
                              4spdragtop CONGRATS NORTH AMERICA! FABO Gold Member
                              32,071
                              12613
                              Aug 28, 2009
                              Wasting time here
                              Local Time:
                              3:24 PM
                              With the limitations you have, I would go wood, BUT do it safely
                              FYI I have a suspended 45kbtu MaxHeater that runs off propane. The orifice I bought was $30 to switch it to NG. Without insulating, any gas burning furnace is gonna be a waste of $$.
                              • Agree Agree x 1
                              • Joey4speed
                                Joey4speed FABO Gold Member FABO Gold Member
                                1,346
                                1026
                                Jul 17, 2018
                                Coastal NC
                                Local Time:
                                4:24 PM
                                Electric is out of the question, especially if you dont have 220v.
                                This propane "sunflower" is the quickest and easiest way to stay warm in a pinch.
                                Maybe work on a more permanent solution next summer.
                                • Agree Agree x 4
                                • Dave 74 Dart
                                  Dave 74 Dart FABO Gold Member FABO Gold Member
                                  537
                                  845
                                  Jan 24, 2019
                                  Southwestern Ontario
                                  Local Time:
                                  4:24 PM
                                  When I first built my garage (20'x28') I put plastic vapor barrier on all walls and the ceiling. I used 2 of the " sunflower" top of the tank models( propane) . As I insulated each wall , I just tore the plastic down and replaced it. Now insulated , I use a small construction box heater (220 v) and once it gets to 65° , it barely kicks on.
                                  ( I used a regular household box fan behind the sunflower heater to blow the air further, It helped)
                                  • Like Like x 2
                                  • Agree Agree x 1
                                  • Joey4speed
                                    1,346
                                    1026
                                    Jul 17, 2018
                                    Coastal NC
                                    Local Time:
                                    4:24 PM
                                    Check with your local code enforcement before setting up a wood burning stove.
                                    Alot of municipalities frown on the smoke, especially if its affecting your neighbor
                                    • Agree Agree x 1
