[FOR SALE] Garage sale, Radiators, Springs, brackets, mufflers, Exh tips +more
dano
Evil Handy Man
Gresham, Oregon
All prices are OBO plus shipping. PM with any questions. Will not ship to Canada, sorry to much customs BS.
Tips off my 69 Dart GTS, these are re-pops in Stainless. I cut the ends off but will include them if you want to weld them back on. See pictures. $SOLD
18" Summit racing flex fan part number SUM-G4918. Installed but not used, didn't clear PS pulley due to limited spacer thickness and thick Cold Case Rad core. $30
Champion Aluminum Radiator part number CC2374B. Opened bottom slots to fit my 69 GTS. Works with 70-Waterpump LA Engines or 69 down converted. Worked fine, used very little with correct antifreeze just went to a ColdCase for the unwelded tops. $160
Older Mopar Chrome Distributor clamp. 3 finger style not made anymore, they are 2 finger. $20
New rear drum brake cables for A body with parking brake that run down drivers side. These are the cabled from the frame mount to the drums. $60
SOLD Heartthrob S43122 Turbo mufflers (pair) new and unused. Came with Summit exhaust kit.
72 Up A body Radiator for auto. Had it cleaned and checked out 10 years ago been storage inside since. $120
Holley Sniper black fabricated Valve covers. Inculdes bolts with sealing washers. Complete.
Had to open the heads to help fit my heads. Otherwise Very Nice and no leaks. $70
Hayden 2947 Fan Clutch. New and unused. I tossed the box not knowing it wouldn't fit my ColdCase Rad. $40
Mopar Oval Track Spring part number P4529415. I installed these but never even put weight on them. Decided to go with ESPO Springs. Includes correct Frame mounts. $220 and be prepared for shipping costs. Will not separate. Picture is of them next to my Stock GTS springs.
71-down LA manual trans Bellhousing stud. I bought new and used. Swapped to a TKO and that bell used the 72-up. $15
I'll take the emergency brake cable if you don't sell with small cables or if the buyer doesn't want the long cable.
Please message me if you want anything, I can get you a UPS quote or if its small enough a flat rate UPSP.
