Gas Generator how many watts!!!
General Discussion
  1. SGBARRACUDA
    SGBARRACUDA ROY FABO Gold Member
    20,966
    9142
    Dec 7, 2006
    PLANT CITY FL. and PERRY GA.
    Local Time:
    8:00 PM
    It should say on the spec tag. At least my central AC did.
    • Like Like x 1
    • TexasDart
      TexasDart Well-Known Member
      1,093
      567
      Apr 13, 2010
      Huntsville AL
      Local Time:
      7:00 PM
      Just bought this 3500w inverter from Norhern. About 50 decibel. Electric start. Less than 800 with my veteran discount. Buddy uses them for his car race trailer.
      • Like Like x 2
      • George Jets
        George Jets 1967 Dart 2 Door FABO Gold Member
        5,280
        7285
        Jan 18, 2019
        Farmington MN
        Local Time:
        7:00 PM
        4000 watt generator, 220v, around 500 bucks.
        Someone going to show up with a Camper they want to plug in. Somebody going to have a refrigerator they want to run to keep food cold. Someone may want to run a small AC unit.
        Various 110v outles available to run the band, might need to run a 110v battery charger when one of the guy's batteries went dead cause his alternator quit outputting.
        Lots to consider, charge cell phones with the 12v outlet. This particular one is electronics safe so you can run a computer too. Made to run fairly quiet with a decent muffler on it too.
        Have Fun Dry Camping
        • Like Like x 1
        • Slantsix64
          Slantsix64 Well-Known Member
          3,122
          1286
          May 11, 2014
          SGV
          Local Time:
          7:00 PM
          lol, i love back to the future!!!!!. Well im not worried about how loud the generator will be, i can just run a long extension cable, the music will probably over power it. So from your guys responses 2000-3000 watt would be my best bet? I wanted to rent one but since the way CALIFORNIA is going with this covid shit, probably gonna buy one and use it for more shows! heres the spot its called the nude bowl, was a pool from a nudist hotel that burned down in the 1980s. There will be alot of skating.
          • Like Like x 3
          • diymirage
            diymirage HP@idle > hondaHP@redline
            25,238
            22716
            Oct 12, 2012
            michigan
            Local Time:
            8:00 PM
            With the rolling blackouts yall have in commiefornia why wouldn't you want to buy one?
          • Jadaharabi
            Jadaharabi FABO Gold Member FABO Gold Member
            8,953
            10177
            Jan 8, 2016
            Peoria, Illinois
            Local Time:
            7:00 PM
            Interesting things about the Honda EU generators is you can hook two in parallel. So you can hook 2000s together or you can hook two 3,000s together or two 1,000s together to double your wattage.
            • Like Like x 1
            • trapster
              trapster Well-Known Member
              2,686
              282
              Feb 19, 2009
              Central Florida
              Local Time:
              8:00 PM
              you listed less than 1000 watts, just get an 1500W inverter and run it off of an car battery.
            • pittsburghracer
              pittsburghracer Well-Known Member
              5,711
              10728
              Apr 20, 2016
              Freeport, PA.
              Local Time:
              8:00 PM
              I take both my 2000 watt Honda and 3400 watt Champion generator to the track. Both are very quiet and can be knocked down to a lower output level. The 3400 watt is pulled out if and when I run my big air conditioner in the motorhome. One of these days I will probably buy a bigger one for my house with 220 so I can run my water well pump. Oh my motorhome has a 4000 watt Onan generator that runs great too but is rarely needed.
            • 67Dart273
              67Dart273 FABO Gold Member FABO Gold Member
              50,281
              18829
              Oct 14, 2010
              Idaho
              Local Time:
              5:00 PM
              Actually you can do that with two synchronous generators, but it ain't that easy and you better know what you are doing...............
              • Agree Agree x 1
              • diymirage
                25,238
                22716
                Oct 12, 2012
                michigan
                Local Time:
                8:00 PM
                Why would you even want that?
                Just split the loads and pay attention what you plug into which one
                • Agree Agree x 1
                • 67Dart273
                  50,281
                  18829
                  Oct 14, 2010
                  Idaho
                  Local Time:
                  5:00 PM
                  Maybe you have one BIG load and a too small generator. How'dya think THE GRID works? Matters not where power is generated, hydro, gas turbine, whatever they must be synched
                  It would not be that hard once set up..........Need a switchbox (like a disconnect) to jumper on to the other, and lights to indicate phasing. Get the gensets running close to frequency, as close in speed/ freq as you can and watch the lights. When the lights are out, they are instantaneaously synched, and toss the switch.
                  • Like Like x 1
                  • Bigdummy
                    Bigdummy Not a Nova FABO Gold Member
                    8,894
                    3427
                    Dec 26, 2006
                    Cleburne,Tx
                    Local Time:
                    7:00 PM
                  • Princess Valiant
                    Princess Valiant Duster specialist FABO Gold Member
                    24,341
                    17970
                    Dec 14, 2011
                    Colorado
                    Local Time:
                    6:00 PM
                    So what do you jam? Hard rock....ska punk....??
                    What's your flavor, and do you have any of your stuff on YouTube??
                  • AJ/FormS
                    AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
                    21,383
                    8628
                    Jan 19, 2014
                    South-Central Manitoba,Canada, 900ftelevation
                    Local Time:
                    7:00 PM
                    If memory serves me;
                    Audio Power Amps are rated output, not power required to drive them, which can be many many many more times the output.
                    > and audio amps are rated at a certain distortion level, which at a party, can easily be exceeded...... and when you drive your audio amp into distortion it will require ever more power input.
                    I have two 200 watt @.008THD mono power amps and I run them on separate 15A circuits; and two other stereo amps on a third circuit, and pair of small self-powered subs on a fourth circuit. My audio power meter on the monos, has indicated, at times, over 1000 watts per channel.
                    I have never tripped a breaker but I have not ever actually measured the draw either.
                    Jus saying.
                    I suggest some really really really long extension cabling, which is gonna suck up some power too.
                  • Slantsix64
                    3,122
                    1286
                    May 11, 2014
                    SGV
                    Local Time:
                    7:00 PM
                    hmmm, we have some older stuff we uploaded i guess Hard rock metal psychedelic lol. heres some songs we put together as a little DIY E.P
                  • Slantsix64
                    3,122
                    1286
                    May 11, 2014
                    SGV
                    Local Time:
                    7:00 PM
                    So we bought the generator 4375 watts at harbor freights and we did a smaller show in a river dam, and man was it a good time. Pretty sure this thing will easily power alot more very easy to start first pull heres some pictures thanks again guys!
                  • SGBARRACUDA
                    20,966
                    9142
                    Dec 7, 2006
                    Local Time:
                    8:00 PM
                    Until it takes a shit in the middle of one of your shows. I hope you have a plan B when that happens.
                  • Tooljunkie
                    Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
                    19,493
                    21260
                    Jul 22, 2017
                    Manitoba
                    Local Time:
                    7:00 PM
                    Add fuel stabilizer to every tank. Will save you a lot of grief if you need it in a pinch.
                  • Slantsix64
                    3,122
                    1286
                    May 11, 2014
                    SGV
                    Local Time:
                    7:00 PM
                    lol plan B is the keg!
                  • Slantsix64
                    3,122
                    1286
                    May 11, 2014
                    SGV
                    Local Time:
                    7:00 PM
                    Yes i added some stabilizer to it!
                  • TT5.9mag
                    TT5.9mag Two atmospheres are better than one
                    1,709
                    1672
                    May 5, 2016
                    So cal
                    Local Time:
                    5:00 PM
                    Let us other Cali members know when you do another show and where it will be.
                  • TT5.9mag
                    1,709
                    1672
                    May 5, 2016
                    So cal
                    Local Time:
                    5:00 PM
                    Hell I’ve got a few 6000 gennys I could bring out and loan you.
                  • 512Stroker
                    512Stroker We are all here because we are not all there.
                    2,955
                    2299
                    May 30, 2016
                    Freedom, MO
                    Local Time:
                    7:00 PM
                    This one
                    Honda EU2200i 49-State Inverter Generator with CO-MINDER
                  • Treblig
                    Treblig Well-Known Member
                    7,268
                    4724
                    Oct 5, 2013
                    South Texas
                    Local Time:
                    7:00 PM
                    I still say that 1 .21 Gigawatts would have worked better!!! Or a bolt of lightening.
                    • Agree Agree x 1
