1. TF360
    TF360 Well-Known Member
    1,144
    272
    Apr 25, 2014
    Florida
    Local Time:
    5:15 AM
    Ok, I'm installing a new gas tank cr11e in my 74 Duster. Got a new sending unit with it. The locking ring and rubber gasket fit right in on the Sender, but I read that it might not seal as good. Anybody installed this new Tank with new sender? Any issues with leaking? I can get the ring off the old Tank, but this new one should seal right?
  2. Dana67Dart
    Dana67Dart Most undignified way to get to Colorado!
    1,542
    612
    Jul 16, 2017
    Northern Colorado
    Local Time:
    3:15 AM
    Whats you plans for the old sending unit? Is it OE?
    On my 67 I used the OE ring and the new seal. leaked like a sieve. I added the old one on top of the new one and not another drop!
  3. TF360
    1,144
    272
    Apr 25, 2014
    Florida
    Local Time:
    5:15 AM
    You put the old rubber seal on top of the new one?
  4. dano
    dano Evil Handy Man FABO Gold Member
    2,292
    343
    Aug 22, 2005
    Gresham, Oregon
    Local Time:
    2:15 AM
    If the ring rotates easy its not tight enough. Usually a small hammer and a brass or aluminum punch is whats needed to remove/install the lock ring and seal. Do not use a steel punch as sparks and fuel vapors don't mix well. Since its a new tank, there isn't much to worry about.
    • Thanks! Thanks! x 1
    • Dana67Dart
      1,542
      612
      Jul 16, 2017
      Northern Colorado
      Local Time:
      3:15 AM
      Yep. Made for a snug fit but it held and not a drop. I believe the lock ring welded to the tank is "stretched"out a bit
      • Dusterdenovo
        Dusterdenovo Contentedly Old School FABO Gold Member
        800
        1306
        Dec 10, 2011
        British Columbia
        Local Time:
        2:15 AM
        I put that tank in my car with a new sender / gasket but used the original lock ring. After a while it started leaking so I made a duplicate of the gasket out of a piece of a WW fluid jug and put it between the sender and the lock ring. It was the right thickness to snug it up a bit and hasnt leaked since.
        • 383Scampman
          383Scampman Well-Known Member
          1,173
          430
          Nov 24, 2013
          New Hampshire
          Local Time:
          5:15 AM
          As dano said , sometimes this is tricky and you need a brass drift to secure the lock ring . FYI the lock ring and seal are available separately if you mess up . I suggest that before you install the tank in the car that you put some water in the tank and turn it upside down to check for a leak . I that checks out put shop air or shopvac in the filler hole to dry up the water.
          • TF360
            1,144
            272
            Apr 25, 2014
            Florida
            Local Time:
            5:15 AM
            Anybody use the new sender and tank and not have issues using all the new parts?
          • famous bob
            famous bob mopar misfit
            11,242
            2784
            Aug 14, 2011
            okla
            Local Time:
            4:15 AM
            I used the same set up, w/ the orig. lock ring and new gaqsket, the new lock ring didn`t feel right and leaked. Had to pull the tank to do it, due to the closeness of the dana . Be sure to lubricate the filler neck and seal/ keep the neck squared up in the gasket------------
            • Bad Sport
              Bad Sport HALF A BUBBLE OFF Staff Member FABO Gold Member
              34,630
              13611
              Jun 12, 2010
              The Wolverine
              Local Time:
              5:15 AM
              I would use the old lock ring. I had fits (leaked like a sieve) with the new one that came with my new sending unit, I used the old one and it was fine.
              • Jimacuda
                Jimacuda Well-Known Member
                1,285
                310
                Nov 10, 2006
                Phoenix AZ
                Local Time:
                3:15 AM
                72 Demon, new tank and sending unit, purchased separately. Both came with lock ring/gasket.
                I used the ones that came with the tank and not a drop leaked.
                I went with the theory that it was made to go with that tank so it should seal.
                Plus they just seemed to fit better.:D
                • TF360
                  1,144
                  272
                  Apr 25, 2014
                  Florida
                  Local Time:
                  5:15 AM
                  Thanks you guys. I'm going to try the new one and report back to you guys if it works properly.
                • Dana67Dart
                  1,542
                  612
                  Jul 16, 2017
                  Northern Colorado
                  Local Time:
                  3:15 AM
                  What's you plans for the old sending unit? Is it OE?
                • TF360
                  1,144
                  272
                  Apr 25, 2014
                  Florida
                  Local Time:
                  5:15 AM
                  I'm going to keep it Dana
