Gasket ID Help
jonn6464
1970 Duster
Weatherford, TX
Hey FABO,
I ordered a timing cover and water pump kit from Mancini Racing. It came with a gasket set. I understand that I don't need all of the included gaskets, but there are a few I don't know what they are for, and I don't wanna miss any.
I called Mancini, but they were not much help.
Can anyone ID these gaskets?
This is 4" across...
This is very rigid, feels like it has a metal inner core, about 3" across. There are 2 other paper water neck gaskets in the kit, so I wasn't sure if this is just another water neck option...
No idea what this one is...
#1 Unknown for a mopar application. Looks like heat exchanged gasket on a boat.
#2 choke well in the intake manifold 1970-1972 V8. Someone will need it
#3 universal thermostat gasket. Junk for a mopar.
Thank you very much!
Hey FABO,
First one is one version of the oil filter adapter gasket. Goes under the plate that is under the oil filter adapter. I think that one is for the angle adapter, but it’s been a long time.
Second one is for choke well “tub” that goes in a factory intake.
Third one is a crappy universal thermostat housing gasket. Good material, just trim off what you don’t need.
Edit: I got treed by 413. Lol.
Thank you, much appreciated.
