Hi, I did search the forum for issues relating to mine and it seems like a bad ground. My issue is with the gauge cluster not mounted but plugged in the dash lights, all the switches and gauges work. When I proceed to mount the cluster the dash lights flicker, turn signals turn on. Seem the metal cluster has current.What ground should I be looking for? Thanks.
