Gauges and Tachometer wiring?
Electrical and Ignition
  1. Jonnylightening
    Jonnylightening Well-Known Member
    222
    28
    Mar 4, 2012
    Pennsylvania
    Local Time:
    4:51 AM
    What are some ways you guys hook up your gauges, tachs, and other aux. That need a switched 12v source. I thought abput a secondary fuse block but...
    • Like Like x 1
    • lilnoah
      lilnoah Supercharged slant six with 4 speed and 8.25 FABO Gold Member
      455
      162
      Dec 22, 2014
      Murfreesboro, TN
      Local Time:
      4:51 AM
      I just wired into the original fuse block after I found the keyed 12v source.
    • Jonnylightening
      222
      28
      Mar 4, 2012
      Pennsylvania
      Local Time:
      4:51 AM
      Wasnt really sure on how to do it in a professional mannor. I used to either toggle switch or splicer, but dont want to do either
    • lilnoah
      455
      162
      Dec 22, 2014
      Murfreesboro, TN
      Local Time:
      4:51 AM
      On my fuse box there were spades that I used that were in place for this sort of thing.
    • 4spdragtop
      4spdragtop FABO Gold Member FABO Gold Member
      25,460
      4908
      Aug 28, 2009
      Ontario
      Local Time:
      4:51 AM
    • Jonnylightening
      222
      28
      Mar 4, 2012
      Pennsylvania
      Local Time:
      4:51 AM
      Oh ok i never really looked at my fuse box. Thanks
    • 44070dart
      44070dart How the hell did I get this old
      715
      458
      Jul 9, 2004
      right here ...see me I'm waving
      Local Time:
      10:51 AM
      I'm using another fuse block for the gauges, glove box stereo and the lights for gauges. I using a separate switch off the new block for the gauge lights. Tach is on the left A-pillar so I just ran that off the factory block. I have three more fused terminals for any other additions on the new one.
    • 67Dart273
      67Dart273 Well-Known Member
      39,501
      7141
      Oct 14, 2010
      Idaho
      Local Time:
      2:51 AM
      The problem is, there is no easily accessable "ignition only" source, that is, you don't need/ want (usually) the gauges to come up on accessory. You could tap into the "ignition run" circuit out of the key, add an inline fuse and go from there
