Gear vendor, under overdrive for 727, Anyone have one
Transmission and Drivetrain Tech
  1. mistreta
    mistreta Well-Known Member
    135
    15
    Mar 30, 2007
    Local Time:
    10:59 AM
    Thinking about a Gear vendor under, overdrive for my 727 in my 408 Duster. OK around town
    355 not a long haul gear. Sounds like a good upgrade.
    • Like Like x 1
    • HemiDenny
      HemiDenny HDK Suspension FABO Gold Member
      8,033
      2326
      May 31, 2006
      NW Ohio
      Local Time:
      10:59 AM
      I have a GV on my aluminum case 4-speed....and one in the box for the 727 that is going in my next project. It will split shift like the dump truck I drove in my twenties, but I like it for anytime over 55mph.....especially on the 4-lane doing 65-70 @ 2200-2400 rpm.
      • Like Like x 1
      • HemiMark
        HemiMark Well-Known Member
        7,281
        614
        Jun 2, 2006
        Pittsburgh PA
        Local Time:
        11:59 AM
        I may have to look into one for the dart
      • HemiMark
        7,281
        614
        Jun 2, 2006
        Pittsburgh PA
        Local Time:
        11:59 AM
        If I'm not mistaken there is a floor modification needed?
      • dodgedifferent2
        dodgedifferent2 Well-Known Member
        2,703
        522
        Aug 8, 2008
        southwestern, Ontario
        Local Time:
        10:59 AM
        I debated the gv behind my 4 speed but can't justify the cost. So I keep cruising with the 3.55's
        • Like Like x 1
        • jbc426
          jbc426 Well-Known Member
          2,054
          879
          May 30, 2007
          West Coast
          Local Time:
          8:59 AM
          The ratio of overdrive gear vendors provide is not really worth it. I drove a buddies 727 with gear vendors and was disappointed with the rpm drop when it was engaged.
          If you really want to enjoy your 408, swap in a built 200R4 with a high stall lock-up torque converter. It's like having a 5 speed automatic. The 200r4's first gear is .25 lower than a 727's, and the overdrive is .67 to 1.
          There's a night and day difference between the two ways to add overdrive to your old Mopar. If you drove your car with each set-up installed, you wouldn't ever consider the gear vendors.
        • DesertRat
          DesertRat Well-Known Member
          3,144
          2803
          Jan 22, 2005
          Moses Lake, Washington
          Local Time:
          8:59 AM
          I have a GV unit in my Barracuda. My combo is commando+ 273 build with late model 904 based transmission W/custom lockup converter. I had my 8 1/4 shurgrip built with 3:73 ratio and will be running 245-60R-15 on 6"stock rally wheels. I expect to be running about 2400 rpm at 70 mph.
          Don't know if that is good or bad but those are the cards I chose to play.
        • HemiDenny
          8,033
          2326
          May 31, 2006
          NW Ohio
          Local Time:
          10:59 AM
          Just for discussion....the GV reduction is .78.....takes my 4:30s down to 3.35.
          How much lower do you need in a hot rod?
          I bought my second one second hand / but still in the box....delivered to my door for $1500. There are used ones out there if you want to save some bucks.
          • Like Like x 1
          • mistreta
            135
            15
            Mar 30, 2007
            Local Time:
            10:59 AM
            Interesting, Thank you for your input. The 200R4, what is that used in, is it a bolt in replacement for a 727?
            I would like to know more.
          • limegreen70
            limegreen70 Pokorny Enterprise's
            1,587
            329
            Apr 27, 2014
            Milton PA
            Local Time:
            10:59 AM
            What size rear tires do you have?
          • abodyjoe
            abodyjoe Well-Known Member
            21,971
            8381
            May 22, 2004
            Berlin,N.J. 08009
            Local Time:
            11:59 AM
            have a few friends with them,... all of them love it.. will turn those 3.55 gears in to what? 2.76 i think.. awesome for the highway
            • Like Like x 1
            • Treblig
              Treblig Well-Known Member
              7,413
              5012
              Oct 5, 2013
              South Texas
              Local Time:
              10:59 AM
              The 2004R is Gm overdrive automatic. I have one in my '69 Barracuda. I absolutely love it!! It requires an adapter plate sold by numerous companies. It is not a bolt in replacement. It also requires minor trimming of the upper trans cross member and changes in driveshaft length. The TV cable connects to the carb (adapter bracket so you won't need the Mopar linkages.
              I installed mine complete for about $1800, I did all the labor.
              Treblig
            • ir3333
              ir3333 Well-Known Member
              5,078
              1595
              Jun 1, 2008
              ontario,canada
              Local Time:
              10:59 AM
              408...hmmm,You should be able to boil the hides with 3.23's, which are a nice cruz gear.
              Maybe try a 3.23 gear first...you might be happy right there.I know that doesn't answer your question about a GV,just a thought
            • mistreta
              135
              15
              Mar 30, 2007
              Local Time:
              10:59 AM
              Rear tires are 255/60
            • HemiDenny
              8,033
              2326
              May 31, 2006
              NW Ohio
              Local Time:
              10:59 AM
              just a fuzz shy of 30" tall
              • Thanks! Thanks! x 1
              • jbc426
                2,054
                879
                May 30, 2007
                West Coast
                Local Time:
                8:59 AM
                More than that for my tastes. Heck, even 3.23 are pretty wrung out at 70 mph with a 28" tall rear tire. With 3.91's a .67 overdrive knocks the revs down nicely to an effective 2.62's ratio, and a lock-up converter adds a nice rpm drop too.
              • jbc426
                2,054
                879
                May 30, 2007
                West Coast
                Local Time:
                8:59 AM
                Or you can use a bellhousing and adapter to bolt it to your motor. The car does need some modifications, but the floor pan remains the same. US Cartool makes a crossmember kit for them now.
              • HemiDenny
                8,033
                2326
                May 31, 2006
                NW Ohio
                Local Time:
                10:59 AM
                That is a great option too......especially for hyway use.
                • Thanks! Thanks! x 2
                • DesertRat
                  3,144
                  2803
                  Jan 22, 2005
                  Local Time:
                  8:59 AM
                  Don't forget you have to cut down the tunnel support structure and reinforce it. I considered that transmission but my car was cut and buffed and too far down the road for that option. That mod is best done before paint.
                • jbc426
                  2,054
                  879
                  May 30, 2007
                  West Coast
                  Local Time:
                  8:59 AM
                  I'm a believer in reinforcing the car as much as possible unless it is some kind of numbers matching car for sure. I welded in US Cartool subframe connectors and their full chassis stiffening kit in addition to welding the torsion bar crossmember solidly to the floor, thinning it out in cross section and reinforcing it with my own fabrication.
                  The shock towers on the late 60's A-Bodies are just hanging in the air with a few spot welds at the top to hold them to the inner fenders. I welded mine solidly to the inner fenders from the frame rail up, and have the under fender bracing welded in too. It makes the car feel WAY more solid on the road.
                  I painted my floor and trunk with that roll on bed liner for durability under the carpet. If you are interested in painting the floor and undercarriage body color, you sure would have to do the modifications before paint. I'll spray them all body color once I finally get the exterior paint done.
                • branded209
                  branded209 Well-Known Member
                  173
                  48
                  Sep 30, 2011
                  Stockton, California
                  Local Time:
                  10:59 AM
                  Nope at most a little dent
                • DesertRat
                  3,144
                  2803
                  Jan 22, 2005
                  Local Time:
                  8:59 AM
                  I now have mine installed and tested. I had to lower the transmission crossmember 1 inch to clear properly. But with 3:73-1 gears and 275/60/15 on 8" wheels I am at 2300 RPM at 70 mph-with a lockup converter. It runs well there and the control is fantastic.
                • RogerCox
                  RogerCox Well-Known Member
                  129
                  22
                  Sep 30, 2020
                  Visalia Ca
                  Local Time:
                  8:59 AM
                  I also have a 408 stroker (465 hp) and was thinking of either running 323 gears or getting a Gearvendor and going 391’s.
                  going to be running a 295 tire, if I can brake traction easily with the 408 and the 323 I’ll just save the 3k, not doing to much high way driving.
                  What do y’all think?
                • RogerCox
                  129
                  22
                  Sep 30, 2020
                  Visalia Ca
                  Local Time:
                  8:59 AM
                  am adding Gerst front K member and 4 link in rear (Dana 60). Should I look at getting level 1/2 frame stiffeners? Will also have a 8 pt roll cage.
                • famous bob
                  famous bob mopar misfit
                  19,857
                  8844
                  Aug 14, 2011
                  okla
                  Local Time:
                  10:59 AM
                  Hey , how could .78 reduction ,take some thing down to .95 REDUCTION ---------------------------??
