Gen3 main cap bolts
63SplitWindow
Montgomery County PA
As part of the job replacing the oil pan and pickup for the Gen 3 swap into an A body, it is necessary to remove and swap out 2 of the main cap bolts for the new windage tray. My question is, do the new torque to yield bolts require lube? What is recommended if I do?
I am only replacing 2 bolts on 2 different main caps. I think I can do that without disturbing the other 2 bolts on the maincaps.
Thanks,
Bill
Here's what I found in the 2015-18 Charger FSM I have:
Hopefully you can read that.
Here is a clip of the torque specs. Note that while it does say new fasteners must be used for rods and oil pan bolts, it doesn't say that for the main cap bolts.
Note that the above info is from the 6.2 section of the FSM. The 5.7 shows different specs and it seemed like you were working with a HC motor so I made sure to clip info from that section.
