GenIII A518 Question
New Hemi Engine Swaps
  1. SteveAle
    SteveAle Well-Known Member
    149
    34
    Mar 30, 2009
    Conover, North Carolina
    Local Time:
    5:13 PM
    I am confused on something and hopefully you all can help. I have seen it listed that I will need and that I wont need a spacer.
    A couple sites show using the adapter and spacer when bolting a 518 to the back of a Hemi like the one listed first in my pictures.
    Then some say I only need to run the flywheel adapter like pictured in the 2nd picture.
    I am hoping someone can shed some light on this for me.
    And I should be able to used any shifter that will allow for 4 speed detents if I run a manual valve body? right?
    Thanks for help.
  2. kursplat
    kursplat FABO Gold Member FABO Gold Member
    2,432
    1534
    Aug 24, 2010
    so cal
    Local Time:
    2:13 PM
  3. 408 swinger
    408 swinger FABO Gold Member FABO Gold Member
    1,519
    1306
    Nov 12, 2010
    Iowa
    Local Time:
    4:13 PM
    I can say without a doubt, if running a 3 spd auto(727-904), you only need the ATI flexplate. The 518 is just an overdrive 727. I have not measured converter/crankshaft offset between 727 and the 518.
  4. Ronald C.
    Ronald C. FABO Gold Member FABO Gold Member
    452
    66
    Jul 18, 2018
    Blanket, TX
    Local Time:
    4:13 PM
    Is the second one the ATI Flexplate?
  5. khuebner250
    khuebner250 Well-Known Member
    767
    778
    Jun 3, 2005
    Windsor
    Local Time:
    3:13 PM
    A500 and A518 are 3 speeds the OD and LU are controlled by pressure and solenoids. I'd recommend a hgm controller. Any old shifter will work.
  6. 1973Barracuda
    1973Barracuda Well-Known Member
    1,952
    2144
    Dec 11, 2009
    Local Time:
    5:13 PM
    Depends on what year your 518 is whether you need that controller or not.
  7. khuebner250
    767
    778
    Jun 3, 2005
    Windsor
    Local Time:
    3:13 PM
    Yep I forgot to mention that part. Trans control depends on RH or RE trans.
    • Agree Agree x 1
    • 408 swinger
      1,519
      1306
      Nov 12, 2010
      Iowa
      Local Time:
      4:13 PM
      Yes
    • Krooser
      Krooser Reform School Graduate
      2,204
      1767
      Jul 19, 2015
      Central Wisconsin
      Local Time:
      4:13 PM
      So I borrowed a damper puller from OReillys....did not work.
      So I bought one on Amazon..
      Same puller same result even though the seller specifically said it would.
      BUT...
      I can do a bit of grinding on the puller arms to clearance them and it should work.
      Also cut apart the orange cannisters of death...despite the sludge on the inlet side it was pretty much sludge and metal free on the outlet side. Filter sludge (1).jpg
    • dusted
      dusted FABO Gold Member FABO Gold Member
      490
      450
      Sep 24, 2006
      Creedmoor, NC
      Local Time:
      5:13 PM
      Bouchillon has a new style dished adapter that does not have the spacer. I just got one and can take a pick when i get home.
