Glad to be alive!
Mopar Body and Trim
  1. PistolGrip
    PistolGrip Well-Known Member
    202
    78
    Dec 8, 2005
    Northern Kentucky
    Local Time:
    5:12 PM
    I had a harrowing experience on the expressway in my '66 Barracuda a few days ago. My left front tire let loose & tore up my left front fender, inner fender & lip molding - quite a ride!. I won't know exactly what I'll be needing until the 'body guy' looks at it in early July, but I may be looking for these parts. What do you recommend as to sources? I don't even know what the inner fender looks like. Is it one big piece? Are Early (64-66) A body inner panels (Dart, Valiant, Barracuda) interchangeable? I know the outer fender is unique to the '66 Barracuda, unless the '66 Valiant is the same. I tried Wildcat & Desert Valley with no luck. I'm just trying to get an idea of where to go once I find out what I need. Thanks
  2. BoogieMan67
    BoogieMan67 FABO Gold Member FABO Gold Member
    316
    151
    Dec 24, 2016
    Tennessee
    Local Time:
    5:12 PM
    I don't wanna to come off as an a$$. The car can be fixed or replaced. Just glad you're alright.:thumbsup:
    • Agree Agree x 1
    • MOPARMITCH
      MOPARMITCH Mekong Gold Member FABO Gold Member
      23,409
      17600
      May 15, 2013
      Maryland
      Local Time:
      6:12 PM
      I don't want to be an ass either. How old were the front tires ?
      Glad you are ok...
    • RustyRatRod
      RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
      79,507
      57983
      Jun 7, 2010
      Georgia
      Local Time:
      6:12 PM
      I had that happen on Mother's Day 2015 on the way to work. I was kinda cookin.....unusual for me and my left front tire exploded. I was probably going an honest 60 in a 45. It pulled me all the way across the oncoming lane and into the opposite right of way. Had another car been there, I would have had a bad one. I knew the front tires were older Michelins. They are notorious for the tread lasting so long that the rest of the tire rots around it. That's exactly what happened. I got a set of Yokohama Geolanders aftet that. They are pretty nice.
      Glad you are ok.
    • 65 Dartman
      65 Dartman FABO Gold Member FABO Gold Member
      12,497
      4114
      Sep 24, 2006
      Strasburg, VA
      Local Time:
      6:12 PM
      Glad you're OK!
      The early A inner fenders are all the same as far as I know and is spot welded in numerous places on the frame rail, core support, etc. After you determine what you need, place a Want Ad,
    • halfafish
      halfafish Damn those rabbits, and their holes! FABO Gold Member
      2,553
      2350
      Aug 14, 2016
      SW Washington
      Local Time:
      3:12 PM
      Yes, the 66 is a one-year-only deal for both the Cuda and Valiant. Front fenders will interchange, they are identical.
    • PistolGrip
      202
      78
      Dec 8, 2005
      Northern Kentucky
      Local Time:
      5:12 PM
      I bought the tires (they looked like new) on a set of Cragar s/s wheels over 10 years ago. They (tires and wheels) looked nearly new at the time & the tread still looks good (on the 3 remaining tires)...no sign of aging - at least nothing I can see. I believe the age, EXTREME heat (over 90), long drive (nearly 500 miles) & steady 70+mph speed combined to put me in this spot. I'm replacing the other 3, even though they still look fine. Today I ordered 4 from Tires-easy.com for a little over $200...free shipping.
    • PistolGrip
      202
      78
      Dec 8, 2005
      Northern Kentucky
      Local Time:
      5:12 PM
      Will do. I've never done that before. Thanks
    • PistolGrip
      202
      78
      Dec 8, 2005
      Northern Kentucky
      Local Time:
      5:12 PM
      Thanks, The fact that a Valiant fender will make my search a little less difficult. I'll wait to see what the body guy says about which way is better...fix mine, or replace it.
    • 4spdragtop
      4spdragtop CONGRATS NORTH AMERICA! FABO Gold Member
      32,452
      13563
      Aug 28, 2009
      Wasting time here
      Local Time:
      5:12 PM
      Glad everyone's ok.
      Good luck on repairs. Got pics?? Morbid curiosity...sorry
      • Like Like x 1
      • pishta
        pishta I know I'm right....
        21,408
        10787
        Oct 13, 2004
        Tustin, CA
        Local Time:
        3:12 PM
        Lee Robinson has some Early A parts, I needed some inners also. They are attached by about 45 spot welds (well, seemed that many) Get yourself the HF spot weld buster and a 1/8 drill. Predrill each spot weld (or center punch) dead in the middle and the live center will fit in there so it wont skate. did both sides and never even flipped the bit.
      • brian6pac
        brian6pac Well-Known Member
        5,668
        4027
        Nov 15, 2016
        N.E.Ohio
        Local Time:
        6:12 PM
        I had a set of Michelins on my 1 ton and they had 150.000 miles on them and the rears still had over 1/2 tread on them, unbelievable. The fronts needed replaced but I was amazed how well they held up.
        • Like Like x 1
        • gliderider06
          gliderider06 Well-Known Member
          1,591
          618
          Oct 21, 2011
          Delaware
          Local Time:
          6:12 PM
          In high school, i had a right front tire blow out on my P/U. Threw me right into a ditch. If i recall i was only going around 40 mph. Scared me to death. Ever since then, i replace my tires sooner than needed.
