Glass Scratch Removal?
Mopar Body and Trim
  1. KOZ45
    KOZ45 Well-Known Member
    507
    143
    Mar 11, 2018
    Indiana
    Local Time:
    9:32 PM
    I used some 0000 steel wool and removed a ton of over spray, and 7 years worth of dust and grime from the windows
    The 0000 wool did great and it looks amazingly better
    However, by cleaning the glass I revealed a few decent scratches in some areas of the glass
    Best route or method to filling these in or polishing them out?
    Thanks for any and a info
  2. pishta
    pishta I know I'm right....
    21,804
    11235
    Oct 13, 2004
    Tustin, CA
    Local Time:
    7:32 PM
    • Agree Agree x 2
    • Like Like x 1
    • halifaxhops
      halifaxhops It's going to get stupid around here! FABO Gold Member
      70,765
      41514
      Jan 20, 2014
      Hoppyworld, PA
      Local Time:
      10:32 PM
      Quick fix if you can find it is Glass wax.
    • Phreakish
      Phreakish Well-Known Member
      1,490
      1051
      May 28, 2015
      N. Idaho
      Local Time:
      7:32 PM
    • KOZ45
      507
      143
      Mar 11, 2018
      Indiana
      Local Time:
      9:32 PM
      Who makes it
    • halifaxhops
      70,765
      41514
      Jan 20, 2014
      Hoppyworld, PA
      Local Time:
      10:32 PM
      No idea but the stuff is amazing, also works like rain X. I have a can I got off of e bay a few years ago.
      • Thanks! Thanks! x 2
      • KOZ45
        507
        143
        Mar 11, 2018
        Indiana
        Local Time:
        9:32 PM
        EJ Wheaton Glass Wax is cheap on Amazon
        $12
        • Like Like x 1
        • Thanks! Thanks! x 1
        • dadsbee
          dadsbee FABO Gold Member FABO Gold Member
          1,361
          3040
          Nov 25, 2020
          Penetang, Ontario
          Local Time:
          10:32 PM
          He's gonna need that after taking the steel wool to it!
          You take that piece of glass outside in the sun yet and look through it KOZ45??
        • KOZ45
          507
          143
          Mar 11, 2018
          Indiana
          Local Time:
          9:32 PM
          Yes. It's crystal clear
          0000 steel wool isn't that abrasive
          • Like Like x 1
          • dadsbee
            1,361
            3040
            Nov 25, 2020
            Penetang, Ontario
            Local Time:
            10:32 PM
            Amazing, I have 100's of hours into polishing B body back glass' and I'd never go near them with steel wool.
            • Agree Agree x 1
            • KOZ45
              507
              143
              Mar 11, 2018
              Indiana
              Local Time:
              9:32 PM
            • cudascott
              cudascott It’s a sickness!
              1,999
              948
              Jan 11, 2012
              TN
              Local Time:
              10:32 PM
              I spent hours and hours polishing out scratches in the back glass of the bee. I wouldn’t do it again for it
              it’s major work no doubt about it. If you look close enough you can see some waves in it just not worth the time and effort for results.
            • 1969383S
              1969383S FABO Gold Member FABO Gold Member
              6,741
              3740
              Jan 8, 2012
              Local Time:
              10:32 PM
              It did not work for me! No amount of water and a polishing pad with Cerium oxide helped. Still looking for an alternative!
              Likely hoping for something that is best fixed with some new glass!
              Sometimes you just have to come to grip with the worst and bite the bullet. More than a nail grab and toast, unless you accept that! JMO!
              • Agree Agree x 2
              • pishta
                21,804
                11235
                Oct 13, 2004
                Tustin, CA
                Local Time:
                7:32 PM
                The cerium oxide will actually remove glass so if its i the middle of a pane or windshield, it will make a wave.
                • Like Like x 1
                • Agree Agree x 1
                • 70dart340
                  70dart340 FABO Gold Member FABO Gold Member
                  1,358
                  839
                  Aug 10, 2007
                  Puget Sound
                  Local Time:
                  7:32 PM
                  I used a wool polishing pad at low RPM with Crest toothpaste. It took awhile, but I removed most of a wiper with no blade scratch.
                  • Like Like x 3
                  • Cal Tonsley
                    Cal Tonsley Well-Known Member
                    274
                    450
                    Mar 11, 2017
                    Australia
                    Local Time:
                    2:02 PM
                    I tried cerium oxide powder and didn’t have much success, did some research and discovered 3m Trizact sanding discs, they will do the trick in removing scratches but it’s still fairly difficult to achieve a crystal clear finish. I probably needed more discs LOL. At the end of the day the process involves the removal of material and this is why the results can be variable.
                    FYI, Here’s some instructions from the merchant I bought these discs from;
                    Scratched Glass Repair Process
                    Remove larger scratches and defects using 3M™ Trizact™ Film Disc 268XA (Grade A35) Use grade A35 as the first step in removing larger scratches and defects. A small amount of water triggers the cutting action. Controlled water flow helps reduce heat build-up to keep the glass cooler.
                    Refine scratches, remove scuffs and acid marks using 3M™ Trizact™ Film Disc 268XA (Grades A20 & A10) Use the A20 and A10 discs to refine the scratches left by the A35 disc. Alternatively, start with the A20 disc to remove shallow scratches, scuffs and acid marks. Apply a small amount of water to start the grinding action. Control the water flow to avoid generating too much heat.
                    Refine scratches, remove defective AR coatings using 3M™ Trizact™ Film Disc 268XA (Grade A5) Use the A5 disc to further refine any scratches left by the A10 disc. As in previous steps, apply a small amount of water to start the cutting action. Avoid extended dwell time to minimize heat build-up.
                    Polish and leave glass crystal clear using 3M™ Trizact™ Film Disc 568XA Use this cerium oxide disc for a final polish. To begin, wet the surface slightly with a small amount of water. As you polish, the pyramids of mineral on the surface of the disc will break down to form a slurry-like solution. The polishing action that occurs will remove scratches left by previous levelling steps
                    • Thanks! Thanks! x 3
