71scamp78
Anyone running a gm style hei distributor. Was thinking of trying one
I've run a bunch on AMC v8's. I've run two with divorced coils on magnum 5.9's.Anyone running a gm style hei distributor. Was thinking of trying one
Your not going to run the coil that comes with the big hei distributor.I am in the process of installing one now on my 63 Belvedere.
The car still had the points so I figured,what the heck never did one might as well. Always learning.
Did many of the 73-up conversions from Ma Mopar.Also Lots of Pertronix conversions.
I am waiting as I am not too sure of what coil I should use, also along with running a ballast or not.
Looks like a .7 or less like a .32 Ohm coil is used without ballast.
This all started as my Accel # 8140 coil took a dump after only 1700 miles of use.
I stab these in everything. I can't stand that big clunky cap, Even on gm's. Chrysler 273-360 c.i. SB Compatible ProSeries Ready to Run Distributor - Black Cap
They make standard cap sized HEI distributors.Might be clearance issues at the wiper motor on a small block a body.
As does every "Pro billet" distributor.kinda looks like a knock off of the msd unit.
The Poly in my 64 B has a Mopar Electronic that works well now that I have some good parts (from @halifaxhops )It's a 64 B body i have lots of clearance
Yeah, but yall's are half the price and just as nice. I have one on the shelf. ;)As does every "Pro billet" distributor.
