Got my moser axles, do I need to lube the end bearings?
LXguy
Champaign IL
Hey All:
Got my Moser axles. there were no directions included, so I was curious if I was supposed to lube the bearings at the axle ends?
Thanks
Steve
If they're not tapered rollers, they're Green bearings and sealed - no lube required.
its according to whether you got new green bearings or had your old ones put on. green bearings are the non adjustable permanently lubricated ones.
i imagine you had new bearings put on so they probably are the greens and they need no greasing.
