Grandson of seed truck!...
General Discussion
  1. j par
    j par Well-hung Member
    20,880
    10231
    Jul 2, 2014
    Portland Oregon
    Local Time:
    10:18 AM
    Well after splattering three different distributors across my work bench I finally got one working LOL...
    Cracked retainer trying to get the dowl pin out. Then being ultra careful with the second distributor I broke it as well! LOL
    I did retrieve the correct clip that was broken from that one and then had to go out into the shed and dig out another one that I was hoping that was there. It was a points distributor so nothing easy.. all I needed was that retainer ring on the bottom and a carefully got it off but it was offset.. I had to use the washers from a couple of them to make up the distance...
    :BangHead::BangHead:...
    I spun the oil up into both heads and drop the distributor in..
  2. 318willrun
    318willrun Roadkill '80 D150
    13,461
    13600
    Sep 13, 2013
    I'm here
    Local Time:
    12:18 PM
    that has points?
  3. j par
    20,880
    10231
    Jul 2, 2014
    Portland Oregon
    Local Time:
    10:18 AM
    The second Parts distributor I found out in my shed was a points distributor. All I did was pull the collar off bottom..
    • Thanks! Thanks! x 1
    • sireland67
      sireland67 Well-Known Member
      8,792
      2951
      Oct 27, 2010
      WV
      Local Time:
      1:18 PM
      Did you check to see if it works before dropping it in?
      Easy test with a multi-meter, set the meter on AC volts, hook both wires to the lead out of the distributor, spin the shaft, if the meter moves it’s good.
      • Like Like x 1
      • j par
        20,880
        10231
        Jul 2, 2014
        Portland Oregon
        Local Time:
        10:18 AM
        I didn't check it but the truck was running and unless I did something stupid everything should be fine...
      • Ddaddy
        Ddaddy I'm changing the World... one pixel at a time! FABO Gold Member
        21,437
        26953
        Nov 7, 2015
        SW of Philly PA
        Local Time:
        1:18 PM
        You will know for sure when you try to fire it up!
        • Agree Agree x 1
        • j par
          20,880
          10231
          Jul 2, 2014
          Portland Oregon
          Local Time:
          10:18 AM
          I think now with the rest of the parts coming in on Friday I should be within a week of firing it...
          The plan is to get it running smooth and operating correctly and then I will get a carpet kit door seals and a seat cover. Then up on the chopping blocks after a good cleaning and scrubbing of the bed area... :thumbsup:...
        • 318willrun
          13,461
          13600
          Sep 13, 2013
          I'm here
          Local Time:
          12:18 PM
          LOL... this has turned into a major project :D
          • Agree Agree x 1
          • j par
            20,880
            10231
            Jul 2, 2014
            Portland Oregon
            Local Time:
            10:18 AM
            Turned into? It always has been LOL..
            Are you saying I should have just parted it out....??
          • 318willrun
            13,461
            13600
            Sep 13, 2013
            I'm here
            Local Time:
            12:18 PM
            LOL.... that would've been work too.... :D Absolutely not! I'm saying I'd keep the old girl a while and enjoy the fruits of your labor. What I'm really saying is this: When an unplanned project lands in your lap slurping up your money and time, it isn't always as enjoyable.
            • Like Like x 1
            • j par
              20,880
              10231
              Jul 2, 2014
              Portland Oregon
              Local Time:
              10:18 AM
              It may take a while to sell it so I will drive it until... To ensure it turned out good I did fix it as if I was going to keep it so I'm not going to be afraid to drive it..
              • Agree Agree x 1
              • j par
                20,880
                10231
                Jul 2, 2014
                Portland Oregon
                Local Time:
                10:18 AM
                Got plugs, wires, and muffler today. Got the shop ready for another run at a crap load of small stuff. Hopefully the weather will cooperate...
              • 318willrun
                13,461
                13600
                Sep 13, 2013
                I'm here
                Local Time:
                12:18 PM
                This is the best advertising bill-board you could have. Progression and things being fixed...
                • j par
                  20,880
                  10231
                  Jul 2, 2014
                  Portland Oregon
                  Local Time:
                  10:18 AM
                  Once it's running good and everything's working as it should I will go ahead and order a carpet kit, door seals, and get a decent seat cover for it. There's plenty for a guy to do as far as some more finishing touches which I may get a few more things as I sit on the truck and wait for a buyer, but definitely all the hard stuff will be done..
                  • Agree Agree x 1
                  • sireland67
                    8,792
                    2951
                    Oct 27, 2010
                    WV
                    Local Time:
                    1:18 PM
                    Its not hard to keep those old girls running.
                    • Agree Agree x 2
                    • j par
                      20,880
                      10231
                      Jul 2, 2014
                      Portland Oregon
                      Local Time:
                      10:18 AM
                      Since I did the rubber mats on the sides of the engine I'll do the one under the overflow tank that goes along the front on top of the radiator... I just use the old material to template rubber material..
                      All the brackets and fan and pulleys are all cleaned and painted and ready to go on....
                      New hoses, clamps, spark plugs, wires.. I bought a little inexpensive windshield wiper bag and pump.. the original tank had a crack in it so I'll give it to the new owner and they can have something to look for at the swap meets.. but in the meantime I have functioning windshield washer...
                      New muffler..
                    • 318willrun
                      13,461
                      13600
                      Sep 13, 2013
                      I'm here
                      Local Time:
                      12:18 PM
                      windshield wiper bag?? Now your just having fun :D
                      • Like Like x 1
                      • j par
                        20,880
                        10231
                        Jul 2, 2014
                        Portland Oregon
                        Local Time:
                        10:18 AM
                        It was very inexpensive and I just want everything to work. New wiper blades just everything...
                      • j par
                        20,880
                        10231
                        Jul 2, 2014
                        Portland Oregon
                        Local Time:
                        10:18 AM
                        Again as if it was for me and I don't like stuff not to work...
                      • j par
                        20,880
                        10231
                        Jul 2, 2014
                        Portland Oregon
                        Local Time:
                        10:18 AM
                        More progress..
                      • 318willrun
                        13,461
                        13600
                        Sep 13, 2013
                        I'm here
                        Local Time:
                        12:18 PM
                        • Like Like x 1
                        • j par
                          20,880
                          10231
                          Jul 2, 2014
                          Portland Oregon
                          Local Time:
                          10:18 AM
                          :thumbsup:...
                        • j par
                          20,880
                          10231
                          Jul 2, 2014
                          Portland Oregon
                          Local Time:
                          10:18 AM
                          IMG_20200111_153020.jpg done for the day.. put in battery check lights, wipers, new windshield washer fluid squirter, and touched the starter and all was good electrically... Short list of parts made for tomorrow... Still need to clean the carburetor and probably paint the air filter...
                          • Like Like x 1
                          • j par
                            20,880
                            10231
                            Jul 2, 2014
                            Portland Oregon
                            Local Time:
                            10:18 AM
                            Just need carb final fuel line and air filter..
                            Just have to reassemble the carburetor here and hopefully get ready for a start tomorrow..
                            • Like Like x 3
                            • j par
                              20,880
                              10231
                              Jul 2, 2014
                              Portland Oregon
                              Local Time:
                              10:18 AM
                              Assembled...
                              • Like Like x 3
