Kendog 170
Let the boy go !
I know there are the two types of green bearings for my 8 3/4. Are the snap ring style supposed to be safer or is it just a preference thing?
TIA
TIA
The caged roller bearings. Not the tapered bearings. Green company made or makes them. We call them Green like we call tissues KleenexWhen we talk about "green" bearings, are we talking about any bearing made by a company known as "Green", or are we talking about ball bearings (likely or only made by the Green bearing company) used as replacements in 8.75 (and I guess 7.25) rear axles?
Are we sure that Ford used / is using Green ball-bearings or tapered roller bearings?
I read references to a green STYLE bearing, which could be or is made by Timken (and others). So now I'm confused as to what exactly is meant by "green" here.
Edit: A google AI summary says that there is (or was?) a Green bearing company, and that a green style bearing always refers to a sealed, non-adjustable ball bearing.
Confusingly, another google AI summary says "Yes, Ford does use green bearings, specifically the green bearing brand Green Bearing Company. Green bearings are a type of tapered roller bearing used in various applications, including wheel hubs, and Ford may use them in certain models, such as the Ford Super Duty, as highlighted by The Timken Company. Green bearings are known for their reliability and long life, making them a popular choice for wheel hub applications."
So I'm seeing results here that claim green bearings are ball bearing AND tapered rollers. What is the actual truth here?
The 8 3/4 axles for sure. Let's look on the Dr. Diff website.t the factory bearings in these mopar rear axles were always tapered rollers?
Lots of Ford 9" came with green bearings later. I don't know when the changeover was, but there was one. Also, the 7.25 Chrysler rear used the green bearings for a long time. That's what Vixen has. I know, because I've replaced them. This is the Precision number from O'Reilly.Dana: View attachment 1716392921
8 3/4: View attachment 1716392922
8 1/4 uses caged straight roller bearings: View attachment 1716392923
7 1/4 uses tapered rollers like the 8 3/4 as far as I know. (and I will correct this post if I am wrong)
No Mopars came with caged ball bearings like the Green bearings are. Ford 9" came with caged rollers like the 8 1/4 I believe. @RustyRatRod knows for sure.
Somebody wasn't very smart. That was making noise a long time before it did all that damage.LOL... ya they're great in front hubs with an inch between bearings.!
View attachment 1716393009View attachment 1716393010
I think they call them "Green" bearings, as most guys don't like Green...![]()
The rotor face is gone.Somebody wasn't very smart. That was making noise a long time before it did all that damage.
