1bad360duster
- Joined
- Dec 2, 2009
- Messages
- 315
- Reaction score
- 170
new combo I’m gonna run soon.
360 magnum block stock bores, icon standard weight forged flat tops. It’s 10.7 to 1 compression. Stock rods with arp bolts, stock crank, Mopar performance windage tray, Edelbrock magnum heads flowing 295 at .600 with 2.05 valves. Hydraulic roller 239/247 at 50 .600 lift. Air gap intake with port match and plenum work, with 1.5 inch spacer with four hole taper. 750 brawler race carb. Have electric water pump and fan. 1 5/8 headers with 3 inch x pipe and bullets. Have evac kit installed that’s pulling 4 inches of vacuum at 5500 rpm. This will be in a duster 3200 race ready, 904 with 2.75 low, 4000 stall 9.5 inch converter, 4.10 rear and 29 inch tall 295 drag radials. It’s a previous good working chassis. Guesses?? And what will peak/max horsepower rpm be?
