H.D. vs non H.D. pedals
niceolddart
S.E. Pa.
May be a stupid question for some, but how, by a quick look, do I tell a regular clutch pedal set-up from a H.D. one when it's not in the car?
What do I look for?
Thanks
Maybe this helps..........
This may help as well......
Here is a comparison of the clutch pedals also. HD pedal is the wider spread.
Look up under the dash at the over center spring. On the light duty spring, you will easily see the full spring out in open hooked on each end. On the HD spring, the spring is "incased", is partially hidden from view by a large outer support bracket. What you don't see is that the HD pedals swing on needle bearings whereas the light duty swing on plastic bushings.
