Harley-Davidson Panhead Chopper. Rigid Paughco frame with 6" over Paughco wide Springer front end. 79 ci (stroked to 4.25") Panhead engine with 5100 miles since rebuild. 4-speed trans with 200 miles since rebuild. STD dual plugged Panheads with Shovelhead spigots; allows for running Shovelhead bolt-on exhaust instead of Panhead pinch-fit exhaust. Other parts: S&S Super E carb, 3" open primary belt drive, converted to 12 volt electronic ignition system with dual coils, disc brakes front and rear, 21" laced front wheel, Mustang pillow seat, and 5 gallon tanks. New paint and air-brushed flames on tanks and front fender. Kick start only, but tuned well; usually a one or two kicker. Clean Ohio title as 1956 Harley-Davidson FL.
This is a true chopper, i.e., rigid frame, kick start only, Springer front end, no turn signals, etc... If that's not what you're looking for, then please look somewhere else. No joy rides. This is not a basket case, and therefore not priced as one; $14K. A reasonable offer will not be refused, but no trades will be considered.
No texts, please call 513-934-7023, but not after 9 pm. If I don't answer, please leave a message; I will return your call.
I do not need assistance selling this item. If the ad is still up, it's still available. I will not answer emails asking if the item is still available. I will not be accepting trades of any kind.
