[WANTED] harmonic balancer bolt and washer for 225
65 Dartman
Strasburg, VA
I saw a crank bolt somewhere on my overcrowded workbench earlier today - just a bolt no washer
pishta
I know I'm right....
Tustin, CA
Its a 3/4-16 X 2.25 (just checked one I think is correct out of the tool box). Use your LA's and then remove it after it has pressed on the balancer. Many did not leave the plant with a bolt after the balancer was pressed on. Should be 1 1/4 or 1 1/8 socket.
killerslant
Gobles, Michigan
If you haven't found one yet, PM me and I will send you one just cover postage when you get it. I am by Kalamazoo so it should only take a day or so.
65 Dartman
Strasburg, VA
Take the one killerslant has offered as I the one I thought I had is actually smaller
RustyRatRod
I was born on a Monday. Not last Monday.
Georgia
You haven't found one at the dealer, because they didn't use one. You can certainly add one, though.
cudamark
San Diego
They did so use one. Not common, in fact I don't remember seeing one on any early slant, but, in the later part for the '70's and later, lots of trucks had them. Mostly manual trans applications and engines with the multigroove balancer.
RustyRatRod
Georgia
Ok. I'll it this way. "I" have seen and worked on a LOT of slant sixes in the forty plus years I've been workin on cars and "I" have never run across one that had a crank bolt in it. That includes the lots of them I've seen in junkyards and everywhere else. So the vast majority "I" have seen did not come with them.
Does that make you happier?
cudamark
San Diego
Sure! :thumbsup: It's just I owned and drove a '78 D150 225 435 4speed as a daily driver for over 20 years, and it had one from the factory.
cudamark
San Diego
I parted out a few that had one too. Part# 6025547. It's shorter than a small block one, but, slight longer than a big block. I think I sold all my extras to some slant 6 racers, but, I can look around for a sample if need be.
