I called Brewers 4 a rebuild. said they were backed up till mid summerBrewer's is the best way to go!
Dan is the man.
What would you think? I called Passon same day and they said they could build me one in 1-2 weeksNot surprised.
Unfortunately that's the trend everywhere.
Title says it all
23 ...30.... 2:47/2:66... no O.D. ... nice if it has 4.354 retainer Looking to be cheaper than Passion PerformanceWhat output size, 26 or 30 spline? What gear ratios? What input size, 23 spline or 18 spline? Overdrive?
I have my four-speed with Jamie currently. I think he just tells white lies to get the work in. He has had my transmission for probably over a month now and I haven’t even gotten a phone call from him saying that he started on it. He told me he could get it done in about six weeks when I talked to him. Good thing I don’t need it as soon as I thought.What would you think? I called Passon same day and they said they could build me one in 1-2 weeks
I have had several bearing surfaces spray-welded and machined, if that's your problem .
2.47low transmissions are sorta rare.
Chipped and rounded clutch teeth are easy to repair, been doing it since the late 70s. Back-cutting the damaged ones to prevent jumping out , is just as easy. If that is all your input suffers from, if I had it in my shop, it would take maybe 15 minutes to repair, and that is all free-hand work.
I wish you good luck.
BTW
that is Fourth gear. It's pretty rare to have ONLY Fourth gear damaged like that. Usually Second is the one that gets a chit-kicking.
