scott657
They look like a well made product. I was thinking of investing in a pair
Lift Stand Inc | Made in the USA
Race ramps are $179 for two 6" pieces so you'd have to buy 4 sets or 179 X 4 which comes to $716 plus shipping. But that only gets you 12" off the ground which in my opinion is not enough room to work comfortably under a car all day long??
treblig
I have to learn how to weld! I had a few 2x4's, plus some scrap 3/4" plywood pieces laying around. I added a few 2"x6"'s from Home D and some deck screws and I'm ready to install my TTI exhaust system. I got the cribbing block idea from other FABO member (thanks). (I wish I had a shop & could afford a lift!) Each one is 14" X 22" and 13.5" tall at the tire or about 25" under the frame. I think I'm all in for about $160.00. It still sucks to work on my back, but it's still fun!Nope. Set of 4 of the 12" Race Ramps wheel cribs run $250. And there is free shipping at places like Summit Racing. You don't need the "ramp" parts, nor are any ramps included with the Lift Stands shown above. If you need a couple more inches of height just throw a couple 2 x 6 boards under the stand. Race Ramps Wheel Cribs RR-WC-12
I have two of them, use them on front, work great. Cradles the tires so won't roll out. I use two hand-made wooden stands for the rear. However, I am not comfortable using them on the HD2500, whereas the wooden stands are rock solid. A ton of floor clearance.I have 4 6 ton jackstands. Use them when necessary. I do have a hoist and various other stands.
I have two of the Lift Stands, plenty of support for an auto and safer than ramps, and I use two wooden stands like Woody's. The lift stands cradle the tires so no chance of rolling off.They look like a well made product. I was thinking of investing in a pair
Especially if he's welding a leak in the gas tank..No welding helmet would top that off perfectly
Here are pics of the stands.I have two of the Lift Stands, plenty of support for an auto and safer than ramps, and I use two wooden stands like Woody's. The lift stands cradle the tires so no chance of rolling off.
However, I am not comfortable using them on the Silverado 2500, whereas the wooden stands are rock solid.
Yep. I usually have a 'list' of things to do when I get these babies out. But, with this big belly of mine, and a smooth ridin' floor creeper (with a pillow) it's well worth it.By the time you get done gettin your car on those, it's nap time.
