Have a look at this bushing.
Suspension, Steering and Chassis
  1. Snake
    Snake Mopar Nut
    9,268
    257
    May 22, 2006
    Belleville Canada
    Local Time:
    11:21 AM
    This is upper control arm bushing,it looks like it missing that washer that has bumps on it to bite in when its tighten,please have a look and tell me if so.that creaking noise is back.
  2. 694spd
    694spd Well-Known Member
    819
    188
    May 2, 2014
    Upstate NY
    Local Time:
    12:21 PM
    Your cam bolt is missing. Did it some how fall out?
    • Agree Agree x 2
    • pishta
      pishta I know I'm right....
      14,386
      4042
      Oct 13, 2004
      Tustin, CA
      Local Time:
      9:21 AM
      I think he probably removed it to show us the lack of that washer. Moog offsets do not have one integrated. After 66 they did not have a washer on the outboard: this is <67
      here is a later model with no integral washer
      but I believe it uses a floating one too.
    • Snake
      Snake Mopar Nut
      9,268
      257
      May 22, 2006
      Belleville Canada
      Local Time:
      11:21 AM
      no i removed it to see the bushing the front and rear have barbs to bite in when tightening the cam bolts in the pic i cant see it.
    • Daves69
      Daves69 Well-Known Member
      4,165
      2197
      Feb 20, 2011
      WestOfChi
      Local Time:
      11:21 AM
      Hard to tell for sure from a picture. It wouldn't surprise me if it were missing as some bushings are sold with out them or someone "couldn't get the a-arm in with it on".
      Here's an A-body bushing end measurement if it can help..….
    • Snake
      Snake Mopar Nut
      9,268
      257
      May 22, 2006
      Belleville Canada
      Local Time:
      11:21 AM
      ya the pic is not too good this pic is off my old 69 dart,as you can see the washer with barbs around it is there ,i will get a better close up of the bushing.
    • Snake
      Snake Mopar Nut
      9,268
      257
      May 22, 2006
      Belleville Canada
      Local Time:
      11:21 AM
      here is the best pic i think i am right need someone to confirm.
    • Daves69
      4,165
      2197
      Feb 20, 2011
      WestOfChi
      Local Time:
      11:21 AM
      You might check that hole dimension. Would that end in the picture I posted fit in there? I'm thinking the bushing steel should have a c'bore to accept it if it were designed to have one.
    • H22A4
      H22A4 Well-Known Member
      1,564
      432
      Aug 4, 2006
      YVR
      Local Time:
      9:21 AM
      Based on what pishta has posted, do you think your bushing is missing the collar/integral washer?
      What additional information do you need? You’ve posted the same question on FBBO so why not hang tight and get the second opinion there?
    • mbaird
      mbaird mbaird FABO Gold Member
      4,451
      1593
      Dec 10, 2005
      boise, Id
      Local Time:
      10:21 AM
      Aftermarket ushings had the washers but factory did not. At least the NOS ones I had didnt.
      Does anyone know if I can still get those collars ?
    • mbaird
      4,451
      1593
      Dec 10, 2005
      boise, Id
      Local Time:
      10:21 AM
      After looking at Pishtas pics I may stand corrected... my memory may be tricking me... but I do recall thinking the Moog washers looked odd when I opened the box
    • replicaracer43
      replicaracer43 Old school member
      3,877
      2392
      Oct 10, 2008
      Local Time:
      11:21 AM
      Your supposed to remove the old washer from the bushing and reinstall it in the new bushing. I have done tons of them. It's common sense, really.
    • 6pk2goDemon
      6pk2goDemon Mopar Mod Staff Member FABO Gold Member
      11,534
      2586
      Mar 1, 2008
      Arizona
      Local Time:
      9:21 AM
      Your style suspension requires those washers at both ends of the bushings.
      • Agree Agree x 1
      • Snake
        Snake Mopar Nut
        9,268
        257
        May 22, 2006
        Belleville Canada
        Local Time:
        11:21 AM
        Well i took of that arm,dont let me work on your car ever what an ass,i think its time to give up on this hobby,this is what i found.
      • mbaird
        4,451
        1593
        Dec 10, 2005
        boise, Id
        Local Time:
        10:21 AM
        Looks like a lower Control arm bushing ?
        Anyone that denies ever screwing something up while working on their car is either a pathalogical LIAR or..... they dont drink !
        Dont know which is worse.....lol
        • Agree Agree x 1
        • Snake
          Snake Mopar Nut
          9,268
          257
          May 22, 2006
          Belleville Canada
          Local Time:
          11:21 AM
          thanks bro i need that
        • H22A4
          1,564
          432
          Aug 4, 2006
          YVR
          Local Time:
          9:21 AM
          So what shop did the work?
        • Snake
          Snake Mopar Nut
          9,268
          257
          May 22, 2006
          Belleville Canada
          Local Time:
          11:21 AM
          Got the bushings in at 930 and all is back together NO NOISE ,I WILL NOT MAKE THAT MISTAKE AGAIN.
          • Like Like x 1
          • H22A4
            1,564
            432
            Aug 4, 2006
            YVR
            Local Time:
            9:21 AM
            So did you have the right bushings originally? Did you supply the bushings or did the shop buy and install the bushings? Are the new bushings different from the ones that squeaked?
            Where was(were) the error(s)?
            • Agree Agree x 1
            • pntastar69
              pntastar69 Well-Known Member
              1,411
              90
              Dec 28, 2006
              Gilbertsville, PA
              Local Time:
              1:21 PM
              You will be getting the front end realigned unless you marked where the cam bolts were.
            • pishta
              14,386
              4042
              Oct 13, 2004
              Tustin, CA
              Local Time:
              9:21 AM
              There is a whole post on stupid stuff we did, but were all still here! I replaced a crank with the motor STILL IN THE CAR and I forgot an upper crank bearing shell! :BangHead:
