ScottieB007
Member
I have a 1977 318 that's going into a truck , I have got everything as close to blueprint as I can , my question is I'm to the point now of CC'ing my heads one come out at 68 cc the other came out at 67 cc factory spec is 63 cc for those heads , if remove the roughly 5 and 4 cc from each head which is like 30 thousanths will I have to mill the intake side of the head or will I be finebecause it's just going down to factory spec , I'm using a performer intake and have had the decks of the block cut smooth which might have removed 10 thousanths from each side of the block thanks for any help
