moparmarkk
Hi,anybody installed a header on a slant?How do you block the egr?thanks for any help,mark
the header and intake do not mate up,but thanks markbecause of the way the exhaust and intake mount on the slantie, you must make sure they are both the same height
(not all headers are created equal)
and especially if you're using second hand parts, you want to make sure its a perfect match
if not, take both of em over to your local machine shop, and have them surface them together
If the valve is intact, and seated,.........Remove the egr valve, flip it end for end, bolt it back on. Egr is now blocked.
