[WANTED] Header woes
Cars and Mopar Parts Wanted
  1. Dart 67 sedan
    Dart 67 sedan Well-Known Member
    76
    24
    Nov 12, 2018
    Richmond Va.
    Local Time:
    6:42 AM
    Contact Seller
    Wanted headers for 65 signot big block 383
  2. Professor Fate
    Professor Fate Push the button, Max...
    1,286
    1667
    Jan 13, 2020
    Wisconsin
    Local Time:
    5:42 AM
    I kinda hate to say this, but unless I've been missing something all these years, you're SOL with a big block early A. C body manifolds or build your own headers is about your only option.
    My best suggestion would be to get some early A (pre '67) LA headers, some big block flanges, and try to make them work.
    I'm sure someone will enlighten us both if I'm wrong.
  3. pishta
    pishta I know I'm right....
    19,135
    8552
    Oct 13, 2004
    Tustin, CA
    Local Time:
    3:42 AM
    Mazollini "Pro-Parts" semi fenderwell headers almost fit. Very close just need a few mods. Probably as close as drop ins come. #5 tube needs to be rerouted and the #8 tube needs to be sectioned out about 2 inches under the fenderwell, EZ as its still on the same plane. Just cut and weld. Steering clearance on the passenger side is the tricky part. YOU DEAD SET ON a B?
  4. RustyRatRod
    RustyRatRod Lemmie see your b00bs. FABO Gold Member
    67,711
    41955
    Jun 7, 2010
    Georgia
    Local Time:
    6:42 AM
    Forget it. Nobody makes um.
    • Agree Agree x 1
    • belmateo
      belmateo Well-Known Member
      1,835
      253
      Mar 29, 2008
      Belmont, California
      Local Time:
      3:42 AM
    • 67charger383
      67charger383 Well-Known Member
      87
      23
      Feb 26, 2020
      Maryland
      Local Time:
      6:42 AM
      You need to hack out the fenderwells and find fenderwell headers. That's the only good way.
    • RustyRatRod
      67,711
      41955
      Jun 7, 2010
      Georgia
      Local Time:
      6:42 AM
      Who said it was "good"? lol
    • satfish
      satfish FABO Gold Member FABO Gold Member
      14
      7
      Oct 10, 2011
      texas
      Local Time:
      5:42 AM
      Engine Size: 440, 413-426 wedge, World Alum block
      Fits: 1967-76 A-body, 62-74 B-body & 70-74 E-body, Raw (Bare Mild Steel)
      $1,131.00
      Maybe?
      TTI not cheap though I don't know how much less room you have compared to the 67 A body but it doesn't look that much different
    • RustyRatRod
      67,711
      41955
      Jun 7, 2010
      Georgia
      Local Time:
      6:42 AM
      Never make it.
    • Dart 67 sedan
      76
      24
      Nov 12, 2018
      Richmond Va.
      Local Time:
      6:42 AM
      I was kinda hoping someone had set they made laying around in their way. Not giving up just yet
    • pishta
      19,135
      8552
      Oct 13, 2004
      Tustin, CA
      Local Time:
      3:42 AM
      You see #5 and #7 tubes going straight down? There is a steering box RIGHT THERE on an early A. #4 and #6 down at the collector is where our idler arms are. Start fabbing! OR you may want to consider HI-Po logs from a Roadrunner, the common ones that go past the #7 port. They actually fit if you trim the steering column tube and shim motor over about 1/4 inch to the passenger side.
    • Dart 67 sedan
      76
      24
      Nov 12, 2018
      Richmond Va.
      Local Time:
      6:42 AM
      Thanks some else said they heard that trick but I haven't had a chance to look into it yet. Think I know where a set are
      buried under pile of parts maybe I can find them before I give up Thanks
      • Like Like x 1
      • pishta
        19,135
        8552
        Oct 13, 2004
        Tustin, CA
        Local Time:
        3:42 AM
        Almost like it was made for 'em. These go for big bucks now for some reason. I got these for $60 a set at a show about 20 years ago, Had to grind off the casting numbers on the passenger side for them to fit. TIGHT!
        Ditch your power steering!
        • Like Like x 1
        • Deweywinger&howe
          Deweywinger&howe Well-Known Member
          112
          75
          Dec 11, 2016
          Floris
          Local Time:
          5:42 AM
          l d start out with new yorker manifolds that resemble magnum s
          power st out of the ?
          You can mill manifold s at an angle if needed
          440 s fits worse local guy 63 dart had his built they hang a little low but work
        • Dart 67 sedan
          76
          24
          Nov 12, 2018
          Richmond Va.
          Local Time:
          6:42 AM
          Will start looking for a set of these. Hi HO Hi Ho on the hunt we go
