Doug's worked fine with mt 71Hello guys. Has anyone found headers that will fit in an originally /6 car converted to a 360 with Schumacher kit. Thanks in advance.
Thank u do u remember the model and they fit with Schumacher mounts?I used regular Hooker headers and coupled it to a Jegs 2-1/2 exhaust. Excellent fit.
Thank u do u remember the model numberDougs fit good for me 74 Dart Sport with schumacher/6 to 340 mounts
Ummmmmm, your freakin kidding me right?!?!Thank u do u remember the model and they fit with Schumacher mounts?
Thank you I appreciate the advice. This is my first mopar build and trying to get the parts in the garage before I tear the car apart.Matt, the Schumacher mounts hold the engine in the factory location. Any header designed for the application will fit. (Be careful about that 5204 I mentioned.) If your engine is mostly stock, the 1 5/8 headers will be what you want. They are routed differently than the 5204's that didn't clear my steering, and are listed to fit a wider range of years. Some will post that the Hooker's are too low, don't fit, etc. Your budget will help you decide.
Maybe you should post how much experience you have with these cars, and what your goals are.
Mostly good, helpful folks on here. I've learned a lot, and have questions every time I start a new aspect of my project.
Welcome to FABO.
Thank you. You guys have been very helpful.Dougs D453
