timk225
I shouldn't be surprised that a 52 year old motor might go bad, that seems to be what's happening.
Even from when I got my 1973 Duster back in the summer of '24, the heater / AC fan motor always worked well and blew air well. But a couple weeks ago it decided to quit.
In my troubleshooting, I ran a wire directly from the battery to the power lead of the motor (it is grounded through the case), and it ran well on high speed.
So I figured that either the on/off electrical switch in the AC controls or the low-med-high fan speed switch had an issue.
But once I got the heater / AC controls out of the dash, I saw problems. Looks like the low-med-high switch got hot, the plastic wiring plug is partly melted.
I had emailed thepartguy.com and he suggested the blower motor might be failing, causing high amp draw, and overheating the switch.
Anyone ever have this problem?
