Heater Vacuum Control Canister
65ChargerDart
65ChargerDart
Fortson, GA
The heater Vacuum Control Canister doesn't work to pull the water valve to "on" on my '65 Dart GT w/factory air.
Are they repairable or where might I find a replacement?
How exacting are you being with this repair? If you require a valve that looks exactly like the factory original, you're going to be in for spending bigger money than if the goal is to get the system working again quickly and efficiently.
Your type of factory air system was used from '65-'72. The heater water valve through '70 (including your '65) has two vacuum hoses going to it: one to open the valve and one to close it. The water valve for '71 and '72 (and carried over into the new-type HVAC system for '73-up) had one vacuum hose; it was spring-loaded rather than having the "other side" vacuum hose. he pre-'71 type (and its vacuum pots, which are separate parts) have been unavailable for years, or very expensive when you can find them; a later-type (single vacuum hose) valve (this one) can easily be installed to get the system working just fine without spending a pile of money. This is a "vacuum closes" valve, so you hook up the hose that used to close your two-pot valve (the hose that has vacuum when the "MAX A/C" button is pushed). Cap the hose that used to open the 2-pot valve (has vacuum in positions other than "MAX A/C") and you're all done—system will work normally for a long time with this $10 repair.
It appears to me that all the vacuum canisters in my system are similar if not the same, the only difference being the nipple position (some are 90* and others are straight. Surely someone has a good canister for which they have no use and would sell reasonably. If not, I'll accept your suggestion and buy the part available on Amazon.
Thanks for the information!
