Hi and thanks. We'll call Dynamic to get the specs. But , I do believe your right on the mfg. If you have any more info send me a message. Thanks again and , may the gods of the asphalt bless you with fast runs and low e.t.s ! !i *think* 11795 is a dynamic number. or at least that's what i remember.
the second sequence p 082x is similar to one that i had but it was something like pc08
lemme see if i can find any paper work on that thing
i found my notes and it was indeed dynamic: 11795 PC0808 3200~3500 stallHi and thanks. We'll call Dynamic to get the specs. But , I do believe your right on the mfg. If you have any more info send me a message. Thanks again and , may the gods of the asphalt bless you with fast runs and low e.t.s ! !
Thanks , we found it .Any pictures?
So, what did the specs end up being?Thanks , we found it .
