Help!! 3.59 Stroker assembly
Small Block Mopar Engine
  1. Bigboy 68
    Bigboy 68 it is what it is FABO Gold Member
    1,354
    197
    May 16, 2017
    Newark,Delaware
    Local Time:
    3:08 PM
    I just purchased a nice set of 3.59 stroker pistons they have .927 pins I need to know what rods I need to get and also where would I get a forged stroker crank for this set up thank you in advance
  2. Ottmundr
    Ottmundr 68 Fastback
    5,613
    8231
    Oct 5, 2012
    Sonoma
    Local Time:
    12:08 PM
    Home - SCAT Crankshafts
    Cast cranks are around three fifty on summit. Forged above seven hundred if memory serves.
    I cant remember the prices on rods.
    On Scat's page just search for Chrysler engines, 3.58 stroke and that should get you to the part numbers list.
  3. 70aarcuda
    70aarcuda Master Hoader of SBM FABO Gold Member
    15,460
    3958
    Jan 16, 2005
    las vegas
    Local Time:
    12:08 PM
  4. Bigboy 68
    1,354
    197
    May 16, 2017
    Newark,Delaware
    Local Time:
    3:08 PM
  5. 70aarcuda
    15,460
    3958
    Jan 16, 2005
    las vegas
    Local Time:
    12:08 PM
    Thank you
  6. Biff
    Biff Cheep not easy
    4,467
    6771
    Jan 30, 2017
    Middle of the ocean somewhere in Canada
    Local Time:
    12:08 PM
    And that’s why this site is awsome:thumbsup:
  7. rumblefish360
    rumblefish360 So close, yet so far away FABO Gold Member
    38,038
    9723
    Jun 21, 2005
    New York, on a Island
    Local Time:
    3:08 PM
    3.58 stroke in a 340 block?
    • Agree Agree x 2
    • greymouser7
      greymouser7 Vagrant Vagabond “Veni Vidi Vici” FABO Gold Member
      3,328
      2618
      Apr 17, 2010
      78002 down the road from Atascosa, Texas
      Local Time:
      2:08 PM
      What is the part number and information (like compression ratio) for your pistons?
    • rumblefish360
      38,038
      9723
      Jun 21, 2005
      Local Time:
      3:08 PM
      No matter the block, a KB-107 in the proper oversize will work or any equivalent piston, flattop or domed or dished.
    • Bigboy 68
      1,354
      197
      May 16, 2017
      Newark,Delaware
      Local Time:
      3:08 PM
      The Pistons are JE517 domed piston 11.75 compression 40 overbore 3.59 340 pistons
      • Thanks! Thanks! x 1
      • stixx
        stixx Well-Known Member
        785
        553
        May 30, 2006
        Southern Germany
        Local Time:
        8:08 PM
        Confusing to me is the 3.59 number... either it's 3.58 (Mopar 360 but not a stroker), or it's 3.79 which in fact would be a stroker crank.
        There are cranks for both strokes available... what rod length to use depends solely on the compression height of your pistons.
        Btw. funny strategy to buy pistons first and then worry about crank and rods? :poke:
      • rumblefish360
        38,038
        9723
        Jun 21, 2005
        Local Time:
        3:08 PM
        Skip the 3.59 thing......
        A 360’s crank stroke is commonly referred at 3.58.
        A 340’s stroke is 3.31.
        The old tyme stroker trick in the ‘70’s was to cut the 360 crank to fit into the 340. This with a .030 overbore makes a 372 cid engine. Or 372.61 exactly which some places round up to 373. Which is fine. Factory does this as well. Up and down in the cid. This makes the stock 360 crank a stroker crank for the 273/318/340.
        I don’t know if there were big stroke stroker cranks available back then. I’m sure the 3.55 cid stroker crank and the down size crank for the 5.0 SCCA racing effort was. I don’t know about the other up stroke cranks like the 3.79 and all the others in between.
        Bigboy’s high compression 372 should be a rip to drive.
        • Agree Agree x 1
        • greymouser7
          3,328
          2618
          Apr 17, 2010
          Local Time:
          2:08 PM
          If Bigboy 68 is Rodney (memory?) he has more mopar stuff than you and me combined. And my garage is full, with the yard overflowing. It’s more about the deal, unique builds for him. He has been known to make full size wagons go fast.
          I never got to see his 67/68 Dart build though.
        • greymouser7
          3,328
          2618
          Apr 17, 2010
          Local Time:
          2:08 PM
          The 355 crank was 3.51” (?yellow alloy?) forged. Not as strong as 4340. I think it was 10XX something alloy.
        • rumblefish360
          38,038
          9723
          Jun 21, 2005
          Local Time:
          3:08 PM
          The 3.55 cranks comes in several (*3 I think*) sizes.
          There a 1053/1054... ahhhh I forget. True, not as strong as a 4340. But that is it a worry point.
          The particular one I have is (IIRC....) a 3.45 stroke.
          • Agree Agree x 1
          • 4spdragtop
            4spdragtop FABO Gold Member FABO Gold Member
            28,959
            9023
            Aug 28, 2009
            Wasting time here
            Local Time:
            2:08 PM
            His name is Bob/Robert Mills, aka Superdart340 or Superdart426.
            Interesting to see what combo he goes with, I'm confused (easily) already.
            • Agree Agree x 1
            • greymouser7
              3,328
              2618
              Apr 17, 2010
              Local Time:
              2:08 PM
              I understand bob mills to be a villain, not the same person I was thinking
              • Like Like x 2
              • Agree Agree x 2
              • yellow rose
                yellow rose Doctor of Thinkology.
                22,043
                18114
                Jun 19, 2015
                Living on the razors edge
                Local Time:
                12:08 PM
                They are 1018 steel.
                • '63GT
                  '63GT Well-Known Member
                  1,024
                  965
                  Jun 9, 2018
                  Turlock, CA.
                  Local Time:
                  12:08 PM
                  Those pistons are probably made for NHRA Stock or Super Stock applications...
                  The rules allow for .010 over stroke, making a OE 360 crank 3.59. it is stamped 3.59 so that the .067 or .070 deck Ht will be correct when the NHRA tech checks it in tear-down.
                  (of coarse the engine builder would know that.. it would be made up for, when the block is cut)
                • greymouser7
                  3,328
                  2618
                  Apr 17, 2010
                  Local Time:
                  2:08 PM
                  This is what he bought:
                  JE pistons, SB Chevy, 4.08 bore, 11.75 compression ratio. | eBay
                  I bet
                • greymouser7
                  3,328
                  2618
                  Apr 17, 2010
                  Local Time:
                  2:08 PM
                  I have that crank 3.51” and those rods that 70aarcuda sold bigboy 68.
                  I was thinking about the eventual rebuild of my 73’ Plymouth Road Runner’s 340 a few years down the road. A few year$ down the road though. The engine runs fine now.
                • rumblefish360
                  38,038
                  9723
                  Jun 21, 2005
                  Local Time:
                  3:08 PM
                  IF in fact true, that is a creative route that would work. Maybe minor machining on the slugs some? (Valve clearance/angles) IDK.
                  After that, or actually before that, it’s piston pin & dome height to the deck height/cylinder head distance to be sorted out.
                  I really don’t see a reason it would t work if your willing to put in the effort.
                  • Like Like x 1
                  • Bigboy 68
                    1,354
                    197
                    May 16, 2017
                    Newark,Delaware
                    Local Time:
                    3:08 PM
                    • Like Like x 1
                    • rumblefish360
                      38,038
                      9723
                      Jun 21, 2005
                      Local Time:
                      3:08 PM
                      Can you leave a more direct link?
                      • Agree Agree x 1
                      • '63GT
                        1,024
                        965
                        Jun 9, 2018
                        Turlock, CA.
                        Local Time:
                        12:08 PM
                        • Like Like x 2
